Where are you getting the bar across the front when standing radiator straight up
Old 03-23-2009, 10:08 PM
kkslds's Avatar
Default Where are you getting the bar across the front when standing radiator straight up
Just like the title says. Just wondering if someone makes this or are you guys fabbing one up yourself. This might have already been asked but couldn't find anything with our awesome search feature. Thanks
Old 03-23-2009, 10:29 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
not sure what your talking about but here's a pic of my rad setup.
Old 03-23-2009, 10:52 PM
SUPERBOOST's Avatar
You can easily make your own,just use a piece of square tube.I used 1x1 about 1/8th wall.
Old 03-23-2009, 11:09 PM
kkslds's Avatar
So you didnt cut all the way through? Most of the ones I have been seeing have been square tubing. Just didn't know if people were custom making them or if someone made something ready to weld in.
Old 03-23-2009, 11:11 PM
kkslds's Avatar
Any pics.? Thanks
Old 03-24-2009, 08:18 PM
no i didn't cut all the way, i boxed it in and did some filler after welding in the reinforcements.
Old 03-24-2009, 08:25 PM
4SFEDZ's Avatar
dont cut any of it out, just cut the bottom of it, the rad will fit under it! this is how i did mine, ill get some pics!
Old 03-24-2009, 09:41 PM
Sideways240sx's Avatar
Chris
Old 03-24-2009, 11:16 PM
kkslds's Avatar
Yea pics would be great. Thanks
And you guys who aren't cutting all the way through. Is the material thats left enough support or Moparnos you said something about adding some extra support. After you smoothed it all out it looks really good like that. Thanks
Old 03-24-2009, 11:36 PM
here's a couple more pics
Old 03-24-2009, 11:48 PM
I just boxed the ends in like this, and hit it with the dupla color that is supposed to match the ta.
Old 03-25-2009, 12:00 AM
Finished pic
Chris
Old 03-25-2009, 01:15 AM
kkslds's Avatar
Both look great. Thanks again. One last question is what is the part number of that radiator your using? Other than hoses what will I need?
Old 03-25-2009, 09:29 PM
i dont remeber off hand i would have to check tomm. hey sideways what alt bracket are you using?
Old 03-25-2009, 09:31 PM
crzytown69's Avatar
clean setups
Old 03-26-2009, 09:10 AM
summit part #GRI-1-25241-X I'm also using -16 hose for the rad.
Old 03-26-2009, 12:20 PM
kkslds's Avatar
-16.. As in a/n fittings right. So will fitting need to be welded on to the radiator?
Old 03-26-2009, 05:46 PM
yes i'm using braided line for coolant hose. and if you do it you need the aluminum bungs from summit too.
Old 03-26-2009, 06:12 PM
Smokin hawk's bracket.
Chris
Old 03-26-2009, 06:15 PM
I just run the stainless steel flexible crap from summit. It has 3 size adapters, for it and you can bend it. I will go to AN the next time i drain the coolant, i just didn't want to spend the money at the time.
You need the hoses, and also need to get a little bung welded in the radiator, then connect the hose from the cross over pipe. It is to releaive pressure in the heads, and you need to hook this up, radiator doesn't have it. Take it to a guy that can weld alum, get a bung welded then get a fitting. I believe i did a 1/4 bung, with a 1/4 90 to a 1/4 barbded fitting, but i could be wrong. it was a while ago.
Chris
