will i have too re tune ?
Old 04-28-2009, 04:22 PM
_916ls1z28_'s Avatar
Default will i have too re tune ?
i have a couple of questions
if i swap my bov for a turbosmart ,turbonetics or tial bov which ever one i get i havent decided , will i have to retune my car. i have a cheap bosch one that y i ask
will i need to retune if i run a turbo timer as well
do i need a manual boost control if im not going to be tampering with the boost im going to keep it at 8lbs with a 44mm tial wg
Old 04-28-2009, 04:25 PM
Smearin's Avatar
you shouldnt have to as long as the setting are all the same.
and
2- dont get a turbo timer.. save the money
Old 04-28-2009, 04:28 PM
HUNTER02SS's Avatar
No re-tune is necessary if you change out your BOV. All it do's is , basicly what it say's it will do. Blow's off excess air pressure. No boost controller is needed as long as you are happy with the boost level that the wastegate spring provides.
Old 04-28-2009, 04:46 PM
do you guys think the bosch will go out really quicklly or can it wait for a month or so before i change it ?
the only reason i asked about the bov because i seen some people made more hp with swiching them thought it would have to be retuned thanks
Old 04-28-2009, 04:59 PM
and
thanks for the input fellas
Old 04-28-2009, 06:48 PM
Smearin's Avatar
Im pretty sure that you are not going to see any gains other than a cooler sounding blow off, all a BOV does is relieve excess pressure when the TB closes, so it doesnt go back through the compressor and spin it in the opposite direction. I recommend the turbo smart mega sonic BOV, is sooo sweet.
Old 04-28-2009, 07:03 PM
calongo_SS's Avatar
I've been running the cheap bosch valves (2) that came with my APS kit for quite a while now. They don't make much noise, but I have no complaints about them. You should be ok as long as you'd like to wait.
