GM 2 Bar map sensor wiring
Old 05-03-2009, 05:21 AM
brianfromhawaii's Avatar
Default GM 2 Bar map sensor wiring
anyone have the wiring guide for this bad boy?
Old 05-03-2009, 07:20 PM
anyone?
Old 05-03-2009, 07:55 PM
crf538's Avatar
if i remember right the middle wire is the signal wire, one of the other should be 5 v and the other ground, if you can turn your key on check them
Old 05-03-2009, 10:27 PM
frcefed98's Avatar
GM 2 bar sensor plugs right into the factory harness, all that is required is the 2 bar OS from HPT/EFIlive etc....
https://ls1tech.com/forums/5001527-post9.html
Old 05-04-2009, 12:11 AM
why do sites sell adapters to them? thats interesting.....
Old 05-04-2009, 05:44 AM
crf538's Avatar
yeah i dont know about the adapter, but it def plugs right in, i figured you needed the signal for some meth or something
Old 05-04-2009, 09:27 AM
EGash's Avatar
If you're referring to the old style 2 bar, (i.e. the one that doesn't directly plug in) It's the same as the 3 bar right? A:ground, B: Signal, C: +5v?
Old 05-04-2009, 09:26 PM
frcefed98's Avatar
I ran the GM 2 bar map sensor (168pn) on my 98, plugs right in to the factory harness. Went 2 bar SD OS from HPT.
I'm now going 3 bar with the MAFT PRO SD with real time WB a/f tracking.
Waiting on the 3 bar MAP sensor from ballenger motorsports....cheapest place I can find em for the gennie made in the USA sensor.
J
Old 05-04-2009, 10:59 PM
This is the plug I have... ^
This is the one I bought ^
Comes with a different adapter.
Old 05-05-2009, 08:42 AM
Gingervitis Addict
slow67's Avatar
Why even go with anything related to the MAF? You are still limited to 512 g/sec.....
Old 05-06-2009, 03:58 AM
bump to top..
Old 05-06-2009, 10:46 PM
frcefed98's Avatar
slow67, who said anything about a MAF? How bout a google LOL. MAFT PRO is a SD=SPEED DENSITY fueling system that is 3 bar ready, can control boost, and has real time WBO2 correction. Yeah you can run a MAF with it, but thats not what I'm doing. I haven't run a MAF in years. Although MAF's can't be too bad. We made 752rwhp on a 396ci LT1 on 15psi with a MAF tune. As for the maftpro Kyle and harlan successfully ran it on his car with great results, I have Kyles old MAFT PRO box.
http://www.maftpro.com/tproinfo.shtml yes one of our sponsors carries it, fullthrottlespeed.com
Brianfromhawaii,
Thats the connector alright.
you bought the wrong MAP sensor, Sorry. The PN's are listed in the Turbo FAQ's at the top of the page. We have the PN's listed with descriptions so its easy as ordering the right PN from the dealer, GMpartsdirect....etc.
TWO BAR SENSOR FOR HPT/EFILIVE 2 bar
GM PN 12580698
New PN for the above sensor, seems GM updated the PN.
12615136
Old 05-07-2009, 11:48 AM
Gingervitis Addict
slow67's Avatar
Well I don't know a whole lot about it, but it looks like it feeds the stock pcm a faked MAF signal based upon its own VE table, which still would limit you to 512 g/sec. Correct me if I'm wrong, but thats what it looks like (I don't know a whole lot about the MAFT setup).
Old 05-07-2009, 01:07 PM
Is there anyway I can make this work?
Old 05-07-2009, 02:35 PM
EGash's Avatar
Yes. Tap the manifold and install a barb fitting (1/8 npt x 1/8 barb will probably work well) run a vac line to the 2 BAR MAP you have and connect the wiring A:ground, B: Signal, C: +5v. A,B,C are labeled on the Orange connector.
Quick Reply: GM 2 Bar map sensor wiring
