Best Internals???
Old 05-03-2009, 10:55 PM
InsaneDomestics's Avatar
Default Best Internals???
What brand of internals (Crank, Rods, Pistons) are you guys using that have Turbo/Supercharger making BIG HP Numbers?
Old 05-03-2009, 11:39 PM
trey04gto's Avatar
Really depends on the $ you want to spend.
Guys have made BIG power on the compstar rods, Diamond pistons, stock crank
REALLY BIG power usually requires something like Oliver billet rods, Wiseco (Turbo) pistons, and a crank like (Sonny Bryant, Callies magnum XL, Callies Dragonslayer)
Old 05-04-2009, 06:20 AM
Fireball's Avatar
by no means the highest power car out there, but it makes a few ponies
Callies Magnum XL crank
GRP aluminum rods
JE pistons
Old 05-04-2009, 06:25 AM
Shawn @ VA Speed's Avatar
need to define big power-means something different to everybody
Old 05-04-2009, 07:26 AM
900+HP, Twin Turbo, or Supercharged. How do the products from SCAT hold up?
Old 05-04-2009, 03:29 PM
Anybody???
Old 05-04-2009, 03:53 PM
trey04gto's Avatar
I would say ehhhhh on the scat stuff.... Atleast go with the compstars w ARP2000 bolts. Those are the cheapest rods I would go with for 900+
The Lunati Pro-billet are nice.
The GRP aluminum's that are in Fireball's BAD *** Virginia speed motor are only good for so many runs as I understand it. All the 1500rwhp and up guys usually use the Aluminum ones
Old 05-04-2009, 04:41 PM
for 1000 hp engines i usually run the compstar crank and rods,they really work good with no issues.If it's going to be a high rpm engine i'll run the callies dragonslayer crank with the compstar hd rods or the lunati billet rods
Old 05-04-2009, 05:46 PM
speedracer5532's Avatar
Callies Dragonslayer Crank
Dyer 300M Rods
Custom JE Pistons
Old 05-04-2009, 06:14 PM
Whats the price on a Dragonslayer Crank, 4.000" and Compstar HD Rods?
Old 05-04-2009, 08:03 PM
we sell the dragonslayer for $1350.00 and the hd rods for 850.00
Old 05-04-2009, 08:08 PM
JAX04's Avatar
ok. so whats wrong with eagle? just asking to level the playing field for all products, and plus i was curious.
Old 05-04-2009, 09:41 PM
Gordon0652's Avatar
Excuse me if i am wrong but the Callies Magnum XL CrankShaft, i though that was for N/A motors because of it's weight and design.
Good internals for 1000hp IMO would be:
Compstar/Dragonslayer Crank
Callies H beam Rods
Diamond/JE/Wiseco Pistons
But i have heard of guys pushing thoes parts ALOT farther!
Also, if you are doing a budget build try using the factory crankshaft. If you are doing a budget build you might want to look in "The Real Price of FI"
Goodluck.
Old 05-04-2009, 11:32 PM
trey04gto's Avatar
Im pretty sure Steve Turley runs the magnum XL in his beast...
Old 05-05-2009, 02:26 AM
SSMOKIN_Y2KSS's Avatar
+2 whats wrong with eagle?
Old 05-05-2009, 05:33 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Nothing once they got their initial issues figured out.
Old 05-05-2009, 05:45 AM
darooke's Avatar
Pistons and rods that i have used for high hp/tq turbo setups is CROWER Rods and weisco pistons. Both brands worked great without a hicup. I am now going to try manleys new turbo piston with teflon coated skirts and manley rods. You already got the cranks listed/ I never used a forged crank so i will not chime in on that. Good luck with your build.
Old 05-05-2009, 05:57 AM
Fireball's Avatar
lightweight don't necessarily mean N/A.
when we tore down the motor over the winter, there was zero evidence of crank flex even at ~1400 FWHP
Old 05-05-2009, 07:31 AM
01ramair500hp's Avatar
im running a callies crank, howards steel rods, diamond boost pistons. going for 1200+ to the ground
Old 05-05-2009, 07:41 AM
Gordon0652's Avatar
Very nice!
Quick Reply: Best Internals???
