my new 76 mm build and new car
Old 05-09-2009, 08:52 PM
25thredrs's Avatar
Default my new 76 mm build and new car
So here is a pic of what i've been workin on for the last year and a half. Theirs more pics soon but these are just two I took recently.
stock bottom end
6.0 heads
speed inc. turbo cam
LOT"S o' fuel
Old 05-09-2009, 09:02 PM
98Camarod's Avatar
Looks good
Any other pics, I'm curious to see how the hot parts are ran. Also do you have an intercooler?
Old 05-09-2009, 09:07 PM
25thredrs's Avatar
hot side
intercooler during mock up
Old 05-09-2009, 09:33 PM
needaz28's Avatar
nice set-up bro!!
I have a buddy with 92 mulet and a 01 lsx. I have always wanted a late 80's gta with a lq4 and boost .
Old 05-09-2009, 09:37 PM
98Camarod's Avatar
How do you have the fueling going to your rails?
Old 05-09-2009, 10:20 PM
ZL1Killa's Avatar
NICE!!! very clean and nicely done!
Old 05-09-2009, 10:47 PM
SScam68's Avatar
Very nice car, but ditch the header wrap.
On a ride that nice it looks cheap.
Get it coated
Old 05-10-2009, 01:57 AM
99Z28LS1's Avatar
Get it coated
I think it looks good. plus it carries a big function...
I will be doing that with my build and also getting my hot side coated
car looks sick bro!
Old 05-10-2009, 08:03 AM
25thredrs's Avatar
I ran a 10 an fro. Sump to y block...then 8 an to the back of each rail.
Old 05-10-2009, 08:20 AM
98Camarod's Avatar
Where do the lines on the front go? To a y then the regulator I assume? I'm just trying to see what you did there. If that is the case, then you could have done it with less line and fewer fittings do get the same result.
Old 05-10-2009, 08:59 AM
25thredrs's Avatar
I ran from the y to the rails then to the regulator...that's how magnafuel and nasty performance recommended to run them
Old 05-10-2009, 09:06 AM
98Camarod's Avatar
Gotcha. Do you have any blowby out of the breather cap? That's the way I was running n/a and then I did my turbo, I had to run each valve cover to a breather tank to fix the blow by. The weird thing is, there's never anything in the tanks.
Great lookin setup, any pics from underneath by chance?
Old 05-10-2009, 10:58 AM
25thredrs's Avatar
Yes I do get some blowby. i'm looking for a better way to vent. Thinking of doing 1 10an hose out of each valve cover then to a catchcan. Then running another hose from the catchcan to the air intake to pull vaccum. let me know if that sounds right or if you think it will work.
Old 05-10-2009, 11:08 AM
98Camarod's Avatar
If you want to have the a pcv system then look at a thread is my catch can routing ok. If its not your dd and you change your oil smaller mile intervals like myself, then just run a hose from each valve cover to two vented catch cans. You can probably get away with one vented catch can though.
Quick Reply: my new 76 mm build and new car
