Spark plug & gap for fi ????
Old 06-10-2009, 03:43 PM
barnat's Avatar
Default Spark plug & gap for fi ????
Hey guys ,Im getting ready to take my ride up to Gettysburgh,Pa this weekend for a tune on my 02 35th APS and currently am running the NGK R TR6 V power plug and was wondering whats the best gap to set these at before i receive my tune??and is this a good FI plug?
Old 06-10-2009, 04:17 PM
conan's Avatar
I have my tr6's gaped to .032.
Old 06-10-2009, 05:36 PM
grpaic's Avatar
anywere between 28-32 is good... got my at 28.... 750 rwhp
Old 06-11-2009, 06:41 PM
OUTLAWZ RACING's Avatar
Got mine at .35 hp in sig very rich afr and meth.
Old 06-11-2009, 06:43 PM
SteelmanLS1's Avatar
Not to ...
But what about a D1SC procharged LS1? What plugs and gap?
Old 06-12-2009, 07:37 AM
conan's Avatar
Originally Posted by SteelmanLS1
Not to ...
Ngk's tr6 gaped to .032, for my procharged ls1.
Old 06-12-2009, 08:15 AM
Restricted User
98Z28CobraKiller's Avatar
I think that plug selection should be made based on the power you expect. I wouldn't run a TR6 on anything over 400 RWHP just for safety's sake. I would run a NGK 7317 (#8) gapped at 28-30
Old 06-12-2009, 08:17 AM
veee8's Avatar
Yeah, I pushed mine too far with the TR6's, it was too hot for my application, even on E85. Of course 16 psi and 24* timing didn't help!
Old 06-12-2009, 09:31 AM
speedracer5532's Avatar
I wouldn't run a projected tip plug in a high hp forced induction application. I am running NGK-4091 which is heat range 7 and is a non-projected spark plug gapped at .029.
Old 06-12-2009, 11:02 AM
2001-WS6's Avatar
It's all about tuning for your combo and street/strip cars have a lot more room than race cars do when it comes to selecting plugs.
TR6s gapped at 28 running with 18 degrees of timing at 19-20psi on pump gas and meth can get you hot lapped 9.4s at 149mph in some cases. Yes an A2W intercooler helps keep those IATs down where everthing is comfortable. In others, TR6s can be a D'ohhhhh!!! but 400rwhp sure isn't the limit to them unless you've really messed something up in a LSx combo.
Simply dropping in colder plugs isn't always the answer. You're trading the colder plug which makes less power, all other things being equal, in the hopes that you can throw more timing or boost at it to net more power on a given fuel combination. You need to get out and tune the car to find what the sweet spot is for your combo and your power goals.
Rick
Old 06-12-2009, 11:43 AM
Hugger Z's Avatar
I am running the TR6's here as well. 538rwhp with mine on 7-7.5psi. And I DD it. No problems with the plugs in my application.
Old 06-12-2009, 11:56 AM
dreamls1's Avatar
I am running TR6 @ .28 673hp 12psi. good luck!
Old 06-13-2009, 01:41 PM
helicoil's Avatar
LS1Tech 10 Year
Rick
Yes, seems from what have seen that a TR6 is just fine through 600RWHP unless you have a crazy stupid tune it.
Old 06-14-2009, 03:45 AM
DarkFormula's Avatar
I run Autolite 104s after switching from the TR-6s about five years ago. .032" gap on Procharger P-1 @ 13psi and making 600+rwhp.
Old 06-14-2009, 04:10 AM
NKAWTG...N
StoleIt's Avatar
TR6's here. I think its gapped at .34 but I can't remember...whatever TTi recommended.
Old 06-14-2009, 09:31 PM
Is that plug good for daily driving?? I mean I run tr6 and meth mainly for top end runs so my wot is alot longer that the drag racer. Im just wondering because that is one of my fears to loose a plug at over 180 mph I even it but first hand is always better.
Old 06-14-2009, 10:35 PM
ss_girl's Avatar
I think I'm going with ngk 7173's on my current build. I searched and searched on here and it seems to be a good plug for my setup.
Old 06-14-2009, 10:57 PM
'Trust''s Avatar
6's at .028 for me, holding 770RWHP fine.
Old 06-14-2009, 11:48 PM
black98ws6ta's Avatar
I have made around 1000 rwhp is 3-4 cars, and 500-800 on a handful with tr6's at 30. I know that people reccomend using a much colder plug for that power level but I tried switching and didnt have much luck.
Old 06-15-2009, 08:07 AM
moehorsepower's Avatar
TR6's gapped at 28, 12lbs 648 RWHP and a DD....No Problems......
Quick Reply: Spark plug & gap for fi ????
