alittle different turbo question
Old 06-22-2009, 08:32 PM
12 Second Truck Club
TURBHOE's Avatar
Default alittle different turbo question
most people ask what turbo for an engine. but i have a tc78 and would like to know what size engine would be the max one would recommend to put it on. max being keeping it efficient and make around 700-800hp. its a tc78 with the largest turbine wheel you can get 68mm IIRC and a .96A/R housing. its currently on a 5.3l but i'm going to have to build it at some point and would like to know what to build it to.
also what would be the minimum CI to spool two of these? that's something else i have thought of.
Old 06-22-2009, 08:34 PM
OUTLAWZ RACING's Avatar
I would say to spool both it would have to be in the upper 400ci range a well built 402 would go nice with a single tc 78.
Old 06-22-2009, 08:52 PM
TURBHOE's Avatar
really? i thought alot of people say not to do 402 with a tc78. if it will work i'd do it. if i have to i would upgrade the a/r of the turbine housing.
Old 06-22-2009, 09:11 PM
TURBHOE's Avatar
i did a search for tc78 on here and came up with a lot of negatives for front mount tc78/402^
Old 06-22-2009, 09:14 PM
WOW I know josh a kypt use that turbo on his kits and make well over 700 hp hmmm... I may have miss somthing but Im pretty sure its a dam good turbo call jose at forceinductions.com for some good imput or josh at kypt.
Old 06-22-2009, 10:34 PM
Johnv's Avatar
What you have is ideal on a 346, a 370 would prob be pretty good as well, I have one on a 383 and think i need to step up to a bigger AR housing, spools up stupid fast though
Old 06-22-2009, 11:28 PM
TurboBandit's Avatar
I have this really cool doorKnob.... Do you have a house that i can buy to go with it? haha...
Sorry, first question just reminded me of it.
Old 06-23-2009, 07:23 PM
TURBHOE's Avatar
not really unless you had a $1000 doorknob and was building a $3000 house. the turbo is install on the truck now. works great but if the motor goes i'll need to rebuild it. not everybody has the money to buy new **** all the time so i would prefer to not have to buy another turbo. so if i can build a good motor that fits the turbo that's what i would rather do. also if i go stock ls1 displacement i can use my stock 5.3l block and not have to buy a new block.
Old 06-23-2009, 07:37 PM
If you have Twins of that turbo, a 408 would do just nicely for 800hp. You'll need about 12~ psi to get there with that setup.
If you're running a single, you could do it with 14-15 psi.
Twin turbo's will give you alot more flow... but remember, you're also cutting the exhaust supply in half by feeding two turbo's. A single turbo will get you more boost down low. (good for daily driver)
By the way... trucks with boost > cars with boost
Old 06-23-2009, 07:58 PM
TURBHOE's Avatar
i agree the down low boost is great for DD. especially in a truck. i need to go look at what a/r housings they make for the tc78. twins sound cool, they really do but then there is that $$$$$ thing again. buuuut if a tc78 will feed a 408 until i gather money for twins that would work!
i agree with the truck thing at the bottom, only my heavy *** truck broke the trans and i'm waiting on mine to get here. oh, how i can't wait.
Old 06-24-2009, 07:20 AM
smokinHawk's Avatar
there is some really bad advise in this thread.............
with that turbo and being a t4 frame, plus i'm thinking you dont want to rev it out to far, i would say the best option would be a 346 cubed and rev it to about 6800-7000
if you want to make a little more power (probably not a whole lot but a little more) and rev it out, build the 5.3 and rev it to 7500 or so.
Old 06-24-2009, 07:49 AM
LS1Tech Sponsor
hellbents10's Avatar
No kidding really bad advice for sure.
From experience with the TC units......370 is the absolute max I would go. Exhaust back pressure even with a 1.15 a/r turbine housing is really high at the 800rwhp mark. They work great on 5.3l's!
To run two of them on a 402 you would want to go with a .81 turbine housing at the 1000hp level and they will not light up any time soon. I would expect full boost at about 5000-5500.
Old 06-24-2009, 11:44 AM
sevanseriesta's Avatar
I disagree with you here. I made 10lbs by 3500 with my 347. So with a 402 I would think you could make 10lbs more by 4000 to no more then 4500
however i also had the t76's
Old 06-24-2009, 04:36 PM
TURBHOE's Avatar
from all the searching i've done it all says the same thing. that a t4 housing is too small. is there a t6 housing for the turbonetics 68mm turbine wheel? what i'm thinking at this point is to bore my stock 5.3l block to 3.898 for some wisecon pistons and use the stock crank. but what rods are good to the rpm you guys ar talking? also i did find a 1.51A/R t4 housing how does that compare for flow compared to a t6 .96?
Old 06-25-2009, 04:32 AM
Denali08's Avatar
Rebuild your 5.3 with good rods and pistons and it should handle the tc78 but not sure if it will get close to 800hp.
Old 06-25-2009, 06:59 AM
smokinHawk's Avatar
a smaller motor will normally make more peak power as the pressure ratios will be better, getting more in the efficiency range of the turbo.
so you will have a better chance of making 800 with the 5.3 then a 5.7
Old 06-25-2009, 07:15 AM
2nd Gen Fl 'bird's Avatar
So you're saying a 5.3 will be a better choice over a 6.0 when using a tc series turbo? That would make my day because those are everywhere here. If anybody can use 650hp on the street, then I personally think they're getting away from a "street car" set up.
Old 06-25-2009, 07:29 AM
LS1Tech Sponsor
We have run the TC78 with a 1.15 a/r on a 370 and it worked pretty good. makes over 800rwhp.
Old 06-25-2009, 12:38 PM
Wow... i think alot of people here are talking about what they have read, not experience.
Remember this... the STS kit with a .60 trim turbo makes 600hp on a 347 @10-11 lbs of boost. Stock engine.
Your 5.3L as it is now, keep your single tc78... they're matched up well.
When you get twins, going to a 5.7L, you'll not be boosting till mid RPMS, not down low at all. It will feel squishy haha.
With the 408, and twins, you'll be able to push 800hp on low boost easily. And you'll get the power down low, and WILL NOT die off. meaning, you will not choke out both of those turbos.
My recomendation... keep the 5.3 and tc78, you'll be golden... Later on, Bore to a 408 and buy another tc78.
Remember... twin .98 a/r turbine housings is a pretty substantial size... and you'll only be spinning it with HALF your engine! You could go to a 1.xx a/r for more power down the road, but i wouldn't worry about it.
Quick Reply: alittle different turbo question
