Found a boost leak...
Old 06-28-2009, 04:00 PM
'Trust''s Avatar
Thumbs up Found a boost leak...
I was gonna head out to get some daytime video of the car today and I was getting my A/C filled before. I stabbed it going up a business district street and it felt like crap, 5psi, felt like a pig. I hunted for a boost leak but couldn't find one and then found this:
I think it happened when I ran an 05 GT on the highway last weekend. I rocked his world but after I let off the blower sounded pretty loud, and today was the first time I had it out since. Pretty cool carnage . It is a solid too, I could barely squeeze it back together then it just popped open again, think ProCharger will warranty it? Lol.
Old 06-28-2009, 04:37 PM
bondosgto's Avatar
damn! you could prolly fix that
Old 06-28-2009, 04:52 PM
MY06TBSS's Avatar
Super glue........... Maybe even silicone......
Old 06-28-2009, 05:07 PM
98Camarod's Avatar
Just use duct tape, that way it blends in
Old 06-28-2009, 05:16 PM
WestSide's Avatar
a few zip ties and it'll be good as new!
Old 06-28-2009, 05:46 PM
SteelmanLS1's Avatar
Think you could find a BAMF welder?
Old 06-28-2009, 05:53 PM
james562's Avatar
Nothing a little JB Weld wont fix
Old 06-28-2009, 06:30 PM
'Trust''s Avatar
Haha, we are going to attempt to repair it and add some bracing and see how it goes.
Old 06-28-2009, 06:33 PM
I honestly think a REAL welder could handle that no problem.
Would be a lot better job than the 8 year old Asian kid that did it the first time.
Old 06-28-2009, 08:10 PM
4SFEDZ's Avatar
ya take it to any welding shop, they would prolly do it for 20-50 buck, and then it would be better than new!
Old 06-28-2009, 08:15 PM
AFASTYZFR1's Avatar
Add in supports and weld it back up......or switch to fmic like I did
Old 06-28-2009, 10:55 PM
Derek@BPP's Avatar
That's crazy..I'm sure Procharger would warranty that.
Old 06-28-2009, 11:04 PM
james562's Avatar
Ive heard this happens when you run too small of a bypass valve and the boost has nowhere to go.
Old 06-28-2009, 11:28 PM
Customizing Director
MadIceV8's Avatar
Oh wow.
Old 06-28-2009, 11:42 PM
ls1_chevelle's Avatar
get it welded, and strap the corner with a piece of aluminum and weld it aswell.
'Trust''s Avatar
I'm going to send a picture to ProCharger and see what they say, I'd like a new one.
50mm BOV is 4" from the plenum, that happened under WOT, I've seen what happens to a car with an inadequate BOV/BPV and it usually folds the TB blades back. Check out this video, you can see it expand like crazy and as soon as it is let off the gas BOV opens and the plenum shrinks immediately:
http://www.youtube.com/watch?v=3UaC3WsnZs4
Old 06-29-2009, 12:37 AM
Rickys S/C Z28's Avatar
man your car is my cars hero!
Old 06-29-2009, 02:05 AM
sr71bbjr's Avatar
Better than your TB blade!
Old 06-29-2009, 07:05 AM
AFASTYZFR1's Avatar
I tried that and and it didn't work for me because I wasn't original buyer......but I would just add supports into yours and weld it up....If you just put a new one on, the same thing will happen.....I even blew a small crack in mine with the procharger race bypass at 16psi. I re-welded mine at least 3 times before I put in the supports. I think it is necessary to have the supports in there for high boost so it doesn't blow up like a balloon.
Old 06-29-2009, 08:13 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Yea, I've seen that happen on quite a few of those metal plenums on here. I think AFASTYZFR1 has the best solution I've seen so far with the supports welded in. Another reason I went with my FMIC before mine popped
Quick Reply: Found a boost leak...
