Mahle Pistons?
I have them. Haven't tested them yet still finishing up little odds and ends before I go get it tuned. I have flat tops with 72cc heads and will be putting 18psi on them! Fingers crossed!
The dish pistons could use a few refinements, but overall they are good pistons. Most piston failures are due to missed or poor tunes. Here and there you will get a defect in one, but the majority of the time other issues cause the pistons to fail. If you are skeptical, use a quality piston from the company's like Diamond, JE, CP, Wiseco, or Race Pack. All of the pistons mentioned will be quality pistons
The building who is going to freshen up the block and install the cam bearings said he is running them in a few high boost motors with no problems whatsoever. I have heard some good things about them from local guys so I just figured I would ask you guys.
