500-550 RWHP guys step in here
hay guys im trying to find out if my car is running were it should be, what are your 1/8 mile and 1/4 mile times? what weight? what gas?
thanks for your help im kinda new at some of this so please excuse the "newbe" questions
Thanks Ricky
Edit also what tires and trans are you running? sorry
Thanks Ricky
Don't have any track times yet, but car in sig made 520 hp / 498 tq on a dyno jet @ 5,600 elevation, 86 deg and 17% humidity, 91 octane, 15 deg of timing 11#'s of boost . I was alittle caught up the numbers at first but the car screams, had about 1-2 cars on a new z06 (50-140 roll) the other night witch made me happy.
Check this out too... https://ls1tech.com/forums/forced-in...up-comers.html
i orig had 488 RWHP, ran 11.1 @ 126-switched to a diff stall converter, ran
10.68 @ 125(i know its not the power level your looking for, just some comparison)
i was running a 6.0 LQ4 with a Procharger, 9 lbs boost and a carb, intercooler
3600 lb car in street trim, 93 octane, 22 degs timing-another dyno showed over 500 RWHP, but it was one of those "cheap ones" though, although i had added some comp. 1.75 rockers, so who knows-do i believe some of the high #'s put out there, well, i beat a guy who claimed 100 hp more than i had, so who knows, diff dynos diff #'s
Restricted User
My old NA setup made right at 500 rwhp thru a th350/5000ish stall. Ran a best of 10.33 @ 128 w/ 3550 race weight I believe.
No clue what kind of power the dyno says now with the new setup. Should be a bit higher as I am coasting thru the traps due to a lower redline.
I am a little above your power range but. my car went 6.9@105mph 1/8 and 10.6@133mph and that was in the heat about 2 weeks ago. car went 10.5 @ 136mph before I added Meth last fall in some nice 35 degree temps. I can't wait to see what mine will do in the fall this year.
