Meth nozzels in a TB spacer plate after the throttle body?
Old 08-17-2009, 11:49 PM
Restricted User
Lawnboy's Avatar
Default Meth nozzels in a TB spacer plate after the throttle body?
has anyone thought of this? and would it be ok to spray methanol in back of the Throttle Body ,
I was thinking of drilling & tapping one of these plates (check link below) and installing 2 small Snow methanol nozzels , one on each side, kinda like a NOS wet TB plate nitrous system.
One reason is because of where my IAT sensor is , in the procharger plemum twin intercooler air box , i cant spray meth in the air box because it is in front of the MAF sensor, cant get that wet!
So i was thinking on installing the AIT sensor in the top of my LS6 intake , where the EGR pipe is on a LS1 intake, now methanol can spray and the AIT sensor can read it.
Let me know what you guys think.
http://cgi.ebay.com/ebaymotors/98-02...Q5fAccessories
Old 08-18-2009, 12:43 AM
black98ws6ta's Avatar
Make sure you use a silnoid on the feed line...otherwise the vacuum from the engine will suck the methanol through the pump.
Old 08-18-2009, 12:52 AM
Restricted User
Lawnboy's Avatar
holly sh5i$^& i didnt think of that
thanks
Old 08-18-2009, 10:08 AM
Adam Connell's Avatar
If you dont have a meth kit already, I HIGHLY recommend you call Julio at Alky Control.
The way we do it on the Turbo Buicks is that we put the Nozzle(or two) in the up pipe from the IC to the TB. It's proven to work, and we have street cars in the 9s running 93 and methanol with dual m15 nozzles on Julios kit.
Im sure we could get them into the 8s, but honestly these car are pure street cars... No one wants to put a funny car cage in their DD.
Julio is the man in the turbo V6 world... Hell Im gunna run E85 with his kit and a preturbo water mist and get rid of my intercooler all together. If I get really ballsy I might throw on a small nitrous shot too!
Old 08-18-2009, 04:32 PM
Johnv's Avatar
I run a coolingmist, they have a check valve inline to prevent meth syphoning through the system when not spraying .
Old 08-18-2009, 04:44 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I have the alkycontrol system on my car. I thought of putting the meth nozzle behind the TB too and asked Julio about that and he said it was a bad idea. I guess because of like what black98ws6ta said- the vacuum inside the manifold would suck the meth thru the lines..
Old 08-19-2009, 09:28 AM
needaz28's Avatar
I have been working on making a "power ring" set-up on my car. I just don't know if I want to do a bunch of small holes (.005-7) with one feed line. Or just 2 nozzles. I had planed to just weld it the tb.
I'm a aerospace machinist so I have all the tools,just need to find the time
Old 08-19-2009, 11:00 AM
dragcamaro's Avatar
you are correct about this entire statement, but you kinda missed the point, what he was trying to get past was a stock location MAF sensor, you have like 3 inches behind it to the tb so this was his idea of a solution. if he was running speed density or had the MAF before the turbo as on a lc2 you could do it that way.
either way id call alky control
Old 10-09-2009, 08:40 PM
imma_stocker's Avatar
vote for speed density???
Old 10-11-2009, 05:44 PM
Restricted User
Lawnboy's Avatar
i ended up installing 2 #7 nossles in the SLP bellow in front of the MAF sensor of course
Old 10-11-2009, 06:10 PM
T/A KID's Avatar
Needs to be after MAF my friend.
Old 10-11-2009, 09:32 PM
ChevyChad's Avatar
true..
Old 10-12-2009, 06:36 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Originally Posted by black98ws6ta
Make sure you use a silnoid on the feed line....
Also remember to put a sticky on my dash board to remind yourself to turn on the solenoid when you need it
Old 10-14-2009, 06:19 PM
Restricted User
Lawnboy's Avatar
yes Friend in front of the MAF sensor and behind the T-body
Old 10-16-2009, 09:57 AM
ChevyChad's Avatar
Your terminology is confusing. How can it be in front of the MAF AND behind the TB???
Look at the intake tract as air flows thru it. You want the meth nozzle BEHIND the MAF so that when it sprays, the airflow doesnt carry the meth into the MAF and ruin the sensor. And you want it IN FRONT of the TB so that when the throttle blade is closed, the vacuum inside the manifold doesn't suck the meth in thru the lines.
Old 10-16-2009, 04:46 PM
BlwnLs1GTO's Avatar
I think he means "behind" it like suggested earlier on.
Carry on...
Old 10-20-2009, 12:44 PM
Restricted User
Lawnboy's Avatar
in front of the MAF sensor , depends how your looking at it, keep on bench racing LOL
Old 10-20-2009, 01:01 PM
ChevyChad's Avatar
ok, i think we can ALL agree it needs to be between the MAF and the TB
Old 10-20-2009, 02:39 PM
Z06PSI's Avatar
I used an old TNT 90mm nitrous ring and plumbed two nozzles into that right before the TB.
Old 10-21-2009, 12:46 PM
Restricted User
Lawnboy's Avatar
ZO6PSI PM sent to you
Quick Reply: Meth nozzels in a TB spacer plate after the throttle body?
