New plumbung cold side & A/W. Pics added from Speed Inc.
6 Second Club Moderator
Has anyone ran a interior mounted I/C with a forward facing manifold? If so I would LOVE to see the pics of the cold side plumbing. Thanks!
Pics added in post 44.
i'm very interested in how that's working for you. i'd like to use A/W on mine, but wasn't sure if it would work there without losing too much passenger space...
Unfortunately, times and money has put the project on hold. Not sure that I will make it out this year
David
I don't see how you can run the LS6 backwards. Seems like it would be a can o worms....what about the sensors? What about the TB cable? How the hel do you fab a pipe from the TB, throgh the firewall when it is so close?
I think I'm just gonna run both cold pipes through the HVAC hole and the "cooled" pipe will just snake around to the TB.
My car is just being finished with the GMPP intake for my LS7 heads and 16 injectors at Speed Inc., but it is forward facing. You could always go with a sheetmetal intake of course.
And, as others have said Duke's car used to have the interior IC with a forward facing throttle body. The IC pipes made a hard 180 turn and went back to the passenger side of the car if I remember correctly.
Would the spacer and slightly larger volume be of any benefit there ?
