lets see those merge pipe pics
Old 08-31-2009, 06:36 PM
brandon1566's Avatar
Default lets see those merge pipe pics
id like to see some pics to see how everyones doing them. I was doing my turbo kit today, when I got to the merge pipe i just couldnt figure out how to get 2, 3" pipes to fit a t3 flange.
Old 08-31-2009, 06:49 PM
JAX04's Avatar
a t3 flange, why?
i would def. think that you would want a t4 flange for a single turbo? what size is the hot side, i bet it spools uber fast.
most people run t4 turbos, for single setup, if that is what you are referring too
Old 08-31-2009, 06:57 PM
frcefed98's Avatar
For a crossover, I use 2.5in tubing merged into the turbo flange. Most of us run single T4 or T6 based turbo's....T3 based turbo would be too small unless you are using em for a twin set up.....i'd think.
Old 08-31-2009, 07:18 PM
it a master power t70, im assuming its a t3/t4 flange I had one laying around that is a t3 and fits the turbo
exhaust housing size is Exducer Diameter 91.0
intake 101.7mm
Old 08-31-2009, 07:37 PM
frcefed98's Avatar
I also had a MPT 70, it was a T4 flange.... .96a/r
Why are you using 3.0 tubing for a crossover? 2.5 is plenty.
https://ls1tech.com/forums/forced-in...unt-01-ss.html
There is a decent merge in this post, I prefer to cut the tubing a bit tighter on both sides and slip it into the flange. Then I hammer form it with heat, vise and a hammer....also a nice block of wood helps form the corners just right. Fit it to the flange and finish weld it.
J
Old 08-31-2009, 07:44 PM
J
honestly its because I had alot of 3 inch mandrel laying around. I'm trying to keep the build on somewhat of a budget. Im pretty sure it will fit the flange im just trying to get some diff idea's on what everyone is doing.
Old 08-31-2009, 08:02 PM
TurboZ28408's Avatar
Old 08-31-2009, 09:37 PM
WS6HUMMER's Avatar
2.5" crossovers will support a LOT of power, I had the same idea to use 3" for a crosover but changed my mind when guys with single digit 1/4 mile cars told me they were running 2.5"
Here's a pic of mine, I used the food color trick to get the angle right.
Its a T4 flange though.
Attached Thumbnails lets see those merge pipe pics-100_1640.jpg   lets see those merge pipe pics-100_1654.jpg   lets see those merge pipe pics-100_1641.jpg
The following users liked this post:
Homer_Simpson (11-12-2021)
Old 08-31-2009, 10:30 PM
KissMySSo1's Avatar
Old 08-31-2009, 10:37 PM
LS1Silverado05's Avatar
Default Here's Mine!
Old 08-31-2009, 10:46 PM
Black_98Z's Avatar
What is the food color trick?
Old 09-01-2009, 12:06 AM
ninetres's Avatar
Some serious Y-pipe **** in here!!!!!!
Old 09-01-2009, 01:11 AM
Turbo LS1 SS's Avatar
Old 09-01-2009, 01:14 AM
Old 09-01-2009, 06:34 AM
Fireball's Avatar
Old 09-01-2009, 06:53 AM
pwrtrip75's Avatar
Old 09-01-2009, 07:55 AM
WS6HUMMER's Avatar
Its a very handy trick to know, I've used it more than once building stuff for other people. Its also a really good way to make a turndown tip out of a 90 or 45*
http://www.theturboforums.com/smf/in...?topic=65147.0
Homer_Simpson (01-10-2022)
Old 09-01-2009, 08:50 AM
RealQuick's Avatar
Some of mine... mig welded
Old 09-01-2009, 11:09 AM
some very nice setups in here!!! thanks lets keep em comming!
Old 09-01-2009, 03:15 PM
7 Second Club
Phil99vette's Avatar
Quick Reply: lets see those merge pipe pics
