boost+4l80e
boost+4l80e
Who is running a 80e with a turbo setup. I am leaning torwards doing the 80e but I would like to see how people like it with a turbo setup. If you could let me know about your setup, converter, times and power. Thanks ahead of time
Lots of guys run them on here. Most seem to really like them. And many are going very fast with them.I have mine on order should be in the car within a few weeks.
I decided not to get a transbrake for now as my car is street car and only going to run a few times at track then retire from tracking it.
I wanted overdrive or would have just got a turbo 400.
Just run a high gear and go th400. If you want, come over and you can go for a ride in zombiess car.....it runs 10.0's here in vegas,with a 2.75 gear. With a 28 inch tall tire, and the 2.75's who needs over drive? It still pulls 180 on hiway.
Ive got a 4l80e in the turbo van, but it needs it. Its 1000+ to change gears, since its awd, and it runs a 29 inch tire, with the oem 3.73's. Besides it ll cruise to other states with 6 people and baggage. It runs high 12's low 13's at 6600 lbs.
In both examples above they basically only use 1st and 2 nd for a pass at the track. I just started short shifting the van, but it barely gets to third. The ets are actually the same wether I hold out second till the line or shift to third. Zombie goes through in second at 136 mph.....with the th400.
Both trans are rosslers BTW.
The 4l80e is a buetiful thing, but way way way more $$$. Going th400 in the van wasnt really an option otherwise I would have.
I have two other turbo camaros, th400 cars, with 3.00 gears and the other with 3.25 gears, with 30 inch tires.
Thanks for the info guys. I have always wanted to take a ride in zombies car but i dont know him to well. He was quite the inspiration when i first got my car, but now i am going traditional mount with my set-up.
I like the 4l80 cause you can get the rossler tbrake and still have fully electronic shifts for every day driving. We went on a mountain cruise yesterday and had I not had the ability to lockup the converter, I would have been in trouble in the mountains.....been there done that. I personally did not want to have to manually shift the car all the time but some folks like that....we are all different
Spoolin here is my info that you asked for
408
s488 turbo
4l80e with yank converter
rossler tbrake
3960# raceweight
3.08 gears
9.39 @ 145 on hoosier drag radials 275/60/15 at 14.5 psi of boost. As far as HP.....whatever it takes to make 3960# go 145mph
408
s488 turbo
rossler tbrake
3960# raceweight
3.08 gears
Last edited by cablebandit; 09-14-2009 at 12:04 PM. Reason: left out requested info
505hp @8psi
stock short block
350 gears in 9 inch
3400 yank convertor
first time out the car went 11.29
this is in a customer's car. so far he has been happy with setup the car was originally a 6 spd.
stock short block
350 gears in 9 inch
3400 yank convertor
Well i have a th 400 now with 2.73 gears and it def cruises nice... but i have a 4l80e waiting to be installed with a set of 3.31 gears.. i have a mvb and trans brake on both so i will see how much better the 4l80e is. But with my weight i can start in 3rd and it drives great lol
4l80e will fit with allot of modifications. the 4l60e is not the greatest automatic, but my stock one seems to be holding up too all the 12 sec passes at the track at 10 psi.
thanks for the info guys!
Cablebandit- how long have you had your 80e set-up? how do you like the transbrake with it? If you dont mind could you pm me how much you paid for the tranny?
who said there exspensive.. i'll sell u one for 600 bucks.. i have three.. i have a ad for them
trying to sell one so i can put a manuel valve body and a 2500-3200 stall for my other 4l80e,, its a turbo 5.3 mpt70 going carb
Have had good luck with mine so far. 8000 miles on the tranny, 70+ 10 sec passes, 3900lb race weight. I've changed the fluid twice when it got cooked from sitting on the trans brake when I had issues spooling in the past, trans has been great, no issues. I have a big trans cooler though as you mentioned. In normal driving I never go over 2500 rpms, converter is really tight around town.
