ahhhh should i stroke my LQ4?? opinions??
Old 09-30-2009, 02:28 AM
KILLER-LS1's Avatar
Default ahhhh should i stroke my LQ4?? opinions??
guys, i just got my LQ motor, and im definitely doing:
forged rods/pistons
ARP head and main studs
edelbrock lingenfelter CNC'd heads
i have the "ebay" PTK kit with a 76mm 81 a/r housing turbo.
i can pick up a basically new eagle 4" crank for $450
so honestly, would it benefit me to just stroke it to a 402 or would that mean more hassle? (bigger turbo? better hot side? etc.)
this is for a STREET car. who cares about my 1/4mile times. I live in so cal and there are no tracks. i just want a car that kills everything else at a red light.
so what would the pros/cons of stroking this motor be??
Old 09-30-2009, 02:34 AM
MelScrilla's Avatar
with that ar and that small of a turbo i would stick with the stock crank. That ar may be small for a 364 LQ4 IMO. if you had a 402 you might spool the turbo on idle. It would be great for smokey burnout shows and short runs but would probably not support a 402 over 5 or 6k rpms.
on another note I'll take the crank for 450 :-)
Old 10-01-2009, 12:50 AM
KILLER-LS1's Avatar
haha well ill get a bigger turbo if i have to.... anyone else running a similar combo?
Old 10-01-2009, 01:02 AM
RS_SS69's Avatar
Thats a little small of a turbo for the 408, im running stock cubes and an GT-88, but im going to be pushing around 20psi. Id say leave the stock cubes and go at it with the same turbo you have.
Old 10-01-2009, 10:42 PM
KILLER-LS1's Avatar
yeah im really looking for the pros and cons of a stroker 408 for a turbo. i can upgrade the turbo if i have to
Old 10-01-2009, 11:44 PM
MelScrilla's Avatar
theres no cons really. the only con would be not having a turbo that matches your cubes.
I say go for the 408 and a monster 91mm turbo if thats not a problem. Since your kit probably comes with a t4 flange the biggest you may be able to go is a 88mm turbo which would still be bad ***.
Matching the turbo is important because to small and you have a stump pulling truck motor(alot of low end instant tq and hp but no top end), and to big you only have an all out drag motor(spools to slow and almost has no use on the street).
Old 10-02-2009, 01:43 AM
transamfreak01's Avatar
he wants a street car. he should not get a 91mm turbo. my advice is to get a st80 or 85 at most
Old 10-02-2009, 11:18 AM
KILLER-LS1's Avatar
exactly. I need to stick with a T4 flange as well, so that limits my turbo choices...
you know the old saying, "theres no replacement for displacent" is really stuck in my head right now... i think im going to do it, and stick with the 76mm just to see how it runs.. and if its chocking out, ill get a new one. if it doesnt choke out, but spools at 800 rpm, even better
Old 10-02-2009, 07:53 PM
TheFallen's Avatar
76mm on a 364 is a good street combo. 402 would end up costing you more then you really want.
Old 10-02-2009, 08:56 PM
KILLER-LS1's Avatar
who said money was the problem? im going to spend a decent amount of money anyways, the only difference is a crank and maybe needing a bigger turbo..
Old 10-02-2009, 10:58 PM
TheFallen's Avatar
didnt say money, was referring to everything
Old 10-03-2009, 12:03 AM
mcmillion's Avatar
So money is not an option. You got the crank and you don't mind buying a new turbo. I really don't see any reason not to stroke it.
Old 10-03-2009, 10:44 AM
Restricted User
98Z28CobraKiller's Avatar
With a 408? Why?
Old 10-03-2009, 06:00 PM
KILLER-LS1's Avatar
yeah, basically i have heard something about increased stress on the piston skirts since the stroke is longer... i have no idea if thats true...
Old 10-03-2009, 07:27 PM
Restricted User
It's actually piston rock at the bottom of the stroke. The piston comes so far out of the bottom of the bore coupled with the tapper of the piston can cause the piston to rock, beat up the skirts and drink oil. There has been lots of debate about this and many of the engine builders will tell you that they have built thousands of 4" stroke setups without issue. It's hard to argue with that but I have personally seen it twice with my stroker motors and I wont use a 4" stroke again.
Old 10-03-2009, 09:54 PM
boosted4life's Avatar
If money isn't the issue, stroke the **** out of it and put the biggest turbo you can find on it.
Old 10-04-2009, 01:27 AM
Jimmy P's Avatar
One would assume that money is a problem since you are using the Ebay kit lol..But on a serious note, I would stroke it and just use a bigger turbo.
Old 10-05-2009, 06:07 PM
KILLER-LS1's Avatar
haha i used it for the hotside, everything else i made... anyways so far i think im going to hone .005" over with the 4" stroke and it should be at 403.1 cubic inches. edelbrock PRO-PORT heads with a custom full CNC by west coast racing cylinder heads with 75cc combustion chambers. depending on the piston, im going to try and get the comp. ratio in the mid nines. should be around 800hp on moderate boost how does that sound?
Old 10-05-2009, 06:16 PM
KILLER-LS1's Avatar
oh yeah and ARP head studs, main studs, flywheel bolts, pressure plate bolts, & intake & exhaust manifold bolts!
Quick Reply: ahhhh should i stroke my LQ4?? opinions??
