View Poll Results: Boost cam
Ling G7
0
0%
2002 Z06
29.17%
EPP cam
37.50%
TR Blower
0
0%
other (please specify)
33.33%
Multiple Choice Poll. Voters: 24. You may not vote on this poll
Which cam do you like for turbo boosting?
Old 10-18-2009, 08:09 PM
The Fugitive's Avatar
Question Which cam do you like for turbo boosting?
Okay so I am trying to see what a lot of people are running for cam's for their turbos. Which one do you like, what do you have, what is your power and how many #'s are you running?
Old 10-18-2009, 09:55 PM
no title here
skyhighsami's Avatar
custom
Old 10-18-2009, 11:10 PM
Originally Posted by skyhighsami
custom
a littlem more info please and that would be an other vote right
Old 10-18-2009, 11:16 PM
elias_799's Avatar
i use a reverse split cam, but my set up is not 100% turbo too small
Old 10-19-2009, 12:37 AM
MY99TAWS6's Avatar
Running ling gt7 with 1.8 yella terras for bit more lift. No dyno numbers till next spring.
Cam has not really any lope and is pretty easy to tune. Do have a bit of low rpm surging though which pretty sure can tune out.
Old 10-19-2009, 02:17 AM
93camaro_zzz's Avatar
Custom reverse split here too.
Old 10-19-2009, 02:19 AM
ninetres's Avatar
I vote custom. And you don't need more details because then your choice would not be "custom" for your set up.
Old 10-19-2009, 02:25 AM
kmracer's Avatar
virgina speed has their line of turbo cams too.
Old 10-19-2009, 08:48 AM
sujomatt's Avatar
I have the EPP FI Cam on a Rear Mounted T67.. other than that just 317 heads and a baby intake.. makes 550 rwhp and rwtq with no meth. Cam sounds sick too
Mind you its a stock bottom end, and EPP states the cam is good for like 1000 IIRC
Old 10-19-2009, 09:45 AM
LS1Tech Sponsor
hellbents10's Avatar
If you are looking for 600, and want it to drive like a stock car around town a ls6 cam cannot be beat.
Old 10-19-2009, 11:21 AM
I'm not asking so I can bite off someone else's set up I want to know to see what works for people with a turbo LSX. I am trying to find a cam that would fit my application yes but I am researching to see what kind of cam works for everyone (lobe separation duration etc etc) setup and rwhp.
Old 10-19-2009, 01:02 PM
9 Second Truck Club
stock48's Avatar
I like my custom single pattern Isky 215/.566'', 114* Does well boosted, and has great response out of boost.
Old 10-19-2009, 01:10 PM
wildta's Avatar
Are you talking about a 347ci or bigger ? how big can you go with that cam ?
thanks warren
Old 10-19-2009, 01:43 PM
LS1Tech Sponsor
No under 6l but to 600whp its a great cam. Even till 800whp it works pretty good, although at that point you would be leaving some power on the table by running it.
Old 10-19-2009, 02:29 PM
hawk584's Avatar
http://leperformance.com/leplsxturbo...rcamshaft.aspx
Old 10-19-2009, 06:39 PM
no title here
Usually people with turbos and that make big power run single pattern or reverse split. Everyone I have seen that made hella good numbers was like that atleast
Old 10-19-2009, 08:05 PM
That LEP cam is pretty interesting, anyone that used it can you post your numbers
Old 10-19-2009, 08:26 PM
Restricted User
98Z28CobraKiller's Avatar
You are leaving power at any power level with that cam. Boost is a power multiplier. Can you make 1000 rwhp with an LS6, yes, it's been done? But you can make it easier (less boost) with a bigger badder cam. But it will cost you a little more and more streetability the bigger you go. It's all a compromise. I went 6.32 @ 109.5 in the 1/8 with the stock longblock (stock heads and cam) at 16-17 psi. My turbo kit is identical but I forged the bottom end, lowered compression, slapped on a set of AFR225's and a Stage 2 Livernois cam 232/232 595/595 114. I believe that I will go faster than that on about 12 psi this Wednesday night.
Old 10-19-2009, 08:39 PM
hawk584's Avatar
here are a few ... and i'm running one in my little LT1
LEP STS turbo Camaro SS Dyno. 634RWHP 661 Torque:
http://www.youtube.com/watch?v=DR4c6qz80GA
http://www.youtube.com/watch?v=5RN9CQnLWp0
http://www.youtube.com/watch?v=42O3U3KJXc0
http://leperformance.com/contact-us.aspx
Old 10-19-2009, 09:00 PM
cablebandit's Avatar
whatever cam makes it idle and fit the rpm range you are looking for if the motor were N/A
Quick Reply: Which cam do you like for turbo boosting?
