View Poll Results: Magnacharger or Procharger?
Magnacharger
15
28.85%
Procharger
37
71.15%
Voters: 52. You may not vote on this poll
Magnacharger vs Procharger
Old 10-29-2009, 08:51 PM
THE_KOON's Avatar
Default Magnacharger vs Procharger
Im trying to decide which i want to go with. Id like to know the pros and cons of both id appreciate it.
Old 10-29-2009, 10:49 PM
MelScrilla's Avatar
I like the procharger because it provides power according to rpm. There is more power in the upper rpm's where maggies start to run out of steam also.
Maggies make killer torque down low kinda like terminator mustangs but i like the way to PC works alot like a turbo and the torque curve looks alot more like a N/A power curve compared to alot of monster torque early and flattening out late.
On a street car a maggie would probably kill people from a stop light if you can get traction, but once the revs get up I bet a PC would walk away from it.
Old 10-30-2009, 02:54 AM
HWI
HWI's Avatar
Prochargers have more potential on an f-body because you can only fit a 112 magnacharger.
Old 10-30-2009, 02:24 PM
doom brincer's Avatar
I love my maggie
[IMG][/IMG]
MTI clear lid ,Kook 1 7/8 LT header, Kook Y pipe Magnaflow cat back, BMR sub frame connector, trans cooler, 160 thermostat, DMH electric cut out, Comp Cam 230 234 115 lsa .60lb injectors, Magnacharger supercharged with water methanol injection, HP tuner. Tune by Matt at TTP Performance Little Fall NJ 530 RwHP-531 RWTQ.
2001 WS6 Transam convertible
Old 10-30-2009, 03:46 PM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=798
The ProCharger D-1SC System in the above link is capable of powering your car into the low 9's in the 1/4 mile with a built engine and suspension. Bob
Old 10-30-2009, 03:54 PM
11SECSS's Avatar
I have to vote for the maggie since I"m in the process of installing one.I was going to do the PC but found a deal on a maggie so I"m going to try it out.
Old 10-30-2009, 05:29 PM
Zeke34's Avatar
+1... What it basically boils down to is what the purpose of your car will be i.e. street stalker, highway robbery, or 1320 *****.
Old 10-30-2009, 05:45 PM
THE_KOON's Avatar
[QUOTE=doom brincer;12440231]I love my maggie
[IMG][/IMG]
GOD that looks like butt sex^^^.
I love the whine of the maggies and i do love the instant insane torque. But i think im looking more into rolling street races. I might go to the track once in a while but i like set up street races better
/QUOTE]
Old 10-30-2009, 05:47 PM
tha joker's Avatar
Plain and simple no more replies needed after this......
MAGGIE for street light to streetlight and quietness
PRO for freeway raping and loud power steering squel sound...
both can do fine at the track
and the pro has more power potential higher in the rpm's
Old 10-30-2009, 05:49 PM
tha joker's Avatar
Originally Posted by doom brincer
I love my maggie
[IMG][/IMG]
WTF why all the orange it makes it look ghetto..just my dumb opinion,if there is a purpose then sorry,but i would of got a different color
Old 10-30-2009, 06:05 PM
'Trust''s Avatar
ProCharger for 2 reasons. 1. Getting anything than a MP112 under there is pretty custom. 2. Maggies are pretty inefficient up top, your IAT's get very high, and there is no way to really cool the charge unless you plumb the lower plenum with alky. They get VERY hot in the higher RPM's, so after 3 runs, you could be down up to 60-80HP.
Old 10-30-2009, 07:21 PM
old motorhead's Avatar
It depends on what your power goals are. If you're limited to an MP112 or MP122, about 550 to 600 at the wheels is about it. If you're good at those power levels, a maggie is tough to beat. 500 ft lbs at 2500 rpm makes for a spritely ride. It moves my 5000 lb truck around like a vette. Mid 12's in hot assed S Texas weather. The rumor that the maggies quit accelerating before 5000 rpm is a little misleading. They don't quit accelerating, they just aren't accelerating at an ever increasing rate like the centris.
If you can shoehorn a TVS2300 in there, you can have it all. Brutal low end and pulls hard on the big end if you're set up right.
Old 10-30-2009, 07:31 PM
THE_KOON's Avatar
i think im gonna go with a maggie cuz i love the kick in the *** right from get go and i think ill be satified with around 600 whp
One more question though will i have to rebuild my bottom end for it or if i keep the psi low should it be able to hold?
Old 10-30-2009, 08:34 PM
Make it breathe easy and you won't need mega boost to meet your goals. Good intake, LT headers, full 3" duals with GOOD flowing mufflers, and mild blower cam with high lift. An MP122 would be a better choice at your power levels if you can swing it. Not sure a 112 would get you where you're wanting to be. TVS would do it easily. The truck in my signature makes over 500 at the wheels on 8psi. That's through a 4L80 tranny, truck diff, and big fat tires. Same motor with a manual tranny and lighter drivetrain should be close to 550 at the wheels.
If your bottom end is healthy and the tune is spot on, you shouldn't have any problems. Upgraded rod bolts might be a good addition.
Old 10-30-2009, 09:23 PM
12 Second Truck Club
supersub's Avatar
Me maggie man!
idle to 6400 rpm!
Old 10-30-2009, 10:45 PM
G Engines's Avatar
The maggie is great if you want power to cruse around on the street but builds a lot of heat at the track. If your going to take it to the track a lot the Procharger is the way to go. Im a track man so I've got to co with the Procharger
Old 10-31-2009, 07:15 AM
just install water methanol injection that will help.
Old 10-31-2009, 02:06 PM
MelScrilla's Avatar
If you go maggie make sure you have a hell of a suspension to hook all the early torque. But alot of people say that they'll be happy at XXX hp but as soon as they get used to the power or get beat by a faster car they want more. That maggie will put you in the range of a pullied GT500 or maybe a KB terminator at best.
The D1SC like trust has can be as mild as 450 or 500 rwhp on a stock bottom end or up to around 800 rwhp on a built motor with no hood clearence issues, heat problems, or changing blowers. And if by some chance 800rwhp gets boring down the road you can always upgrade to a F1 series which will put you around the 1k rwhp mark.
Old 10-31-2009, 02:37 PM
LS1RedZ's Avatar
I definitely agree with him!
Old 10-31-2009, 02:48 PM
Engine_HP's Avatar
maggies looks cleaner but Pro makes more power
Quick Reply: Magnacharger vs Procharger
