Should I dump my 243s for 317s?...
Old 11-07-2009, 01:56 PM
Snyper's Avatar
Default Should I dump my 243s for 317s?...
Like the title says...should I get rid of my 243s for a set of 317s? I plan on running them unported at first..would I be hurting or helping my setup? (ls2 pt88) and does anyone know what the comp ratio would be on a stock LS2 block with these heads and some MLS gaskets?
Old 11-07-2009, 03:28 PM
algws6's Avatar
if you do decide to i have a set of 317s i will trade you.
Old 11-07-2009, 06:42 PM
Snyper's Avatar
condition? And how much are 317s worth? I know these ones go for 400+ reg.
Old 11-07-2009, 10:50 PM
dudeman's Avatar
does the ls2 have flat top pistons?
Old 11-08-2009, 12:58 AM
9 Second Truck Club
stock48's Avatar
Unless running E85 or race gas I would say yes on the 317's. The 243's are probably worth a little more $ than the 317's.
Old 11-08-2009, 01:08 AM
WS6HUMMER's Avatar
317's are better, less prone to detonation due to valve shroud.
Old 11-08-2009, 09:42 AM
algws6's Avatar
they are hot bathed and in great condition. give me your email and i will send you some pics.
Old 11-08-2009, 12:09 PM
Snyper's Avatar
email is transam6383@yahoo.com mine have about 5,000 miles on them with the patriot gold spring setup. What do you guys think about trading for these plus 225$? Can I get that for them with a trade?
Old 11-08-2009, 01:52 PM
algws6's Avatar
put the stock springs on them and i will trade you straight up.
Old 11-08-2009, 04:33 PM
Snyper's Avatar
how about you just take your springs off and send me the heads and valves and ill do the same?
Old 11-08-2009, 07:28 PM
algws6's Avatar
ill send you the heads complete. they are stock springs and i wont be using them. pm my you number and we can work out the details.
Old 11-08-2009, 10:20 PM
elias_799's Avatar
the 243 heads a worth quite a bit more then the 317's. but it is always best to have a big combustion chamber and raise the compression if needed with the piston.
Old 11-08-2009, 11:27 PM
Snyper's Avatar
how much more?
Old 11-08-2009, 11:35 PM
elias_799's Avatar
317 you can get for around 150 bucks, they are easy to find because they come in allot of the chevy trucks equipped with the lq4/lq9 6.0 motors. the 243's only come in the gto's, vettes, and i think the cts-v Cadillac and they usually got for $350+
Old 11-09-2009, 12:16 AM
Snyper's Avatar
I did not know that. Maybe I should try the local junk yard and just sell these...
Old 11-09-2009, 05:12 AM
TheFallen's Avatar
243 also come on 5.3/4.8 of GEN IV also come on LS4s which are on montecarlos and impalas.
Old 11-09-2009, 11:44 AM
RS_SS69's Avatar
Check a junkyard for the 317s, lately on here people are asking stupid amounts for them, like no less than $225 to $300, dont pay over $150 for a set. Your 243s you can sell for at least $350.
Old 11-09-2009, 12:29 PM
Snyper's Avatar
So if I were to trade+200 without my springs that would be about normal?(I have the patriot spring setup)
Old 11-09-2009, 02:10 PM
RS_SS69's Avatar
Yes that would be fair, keep your springs your going to need them.
Old 11-09-2009, 06:04 PM
Snyper's Avatar
I found someone to just buy them outright. I dont mind buying a new set of springs anyways. One question I do have though is I bought 1piece chromoly pushrods and used them with my heads...am I going to need to change them?
Quick Reply: Should I dump my 243s for 317s?...
