Are the '98 Fbody manifolds the only "weldable" stock manifolds?
Old 01-01-2010, 07:25 PM
lazylongboarder's Avatar
Default Are the '98 Fbody manifolds the only "weldable" stock manifolds?
I'm looking to invert stock manifolds to mount the wastegates and turbo's up by the valve covers but this might be useful for quite a few people in many applications. I'll be shortening the collector and putting a t3 flange in it's place right after the merge.
I've read that the 1998 F-body exhaust manifolds are stainless and was curious if there were any other stock manifolds off of LS series motors, ie: escalades, vans, 1500's,2500's that could be welded?
Most truck manifolds all seem to be cast iron making them awesome for big boost but not so awesome to work with. C5's and C6's are cast iron I believe.
Any help would be...helpful
Russ
Target boost is 16-18 lbs. Twins
Old 01-01-2010, 08:05 PM
elias_799's Avatar
i would like to know this as well
Old 01-01-2010, 08:19 PM
wilson34's Avatar
You can weld stainless to cast iron, you just need to use the right rod and technique such as a heating process to preheat the cast.
But yeah, I think the 98's are the only ones not cast iron.
Old 01-02-2010, 08:49 AM
smokinHawk's Avatar
You can weld MILD to cast iron, stainless not so much it will crack to easily
the 99 fbody manifolds are 409 stainless as well identical to the 98's
all the gen3 trucks are cast,
I think the early vettes were steel, but it's pointed down were the fbody motor mounts are. And the gto's, Cadillacs, hhrs are cast as well.
Old 01-02-2010, 10:08 AM
Area 51's Avatar
97 vettes had stainless manifolds too
Old 01-02-2010, 12:13 PM
I'm gonna look into this. So '98's AND 1999 Fbody's as well as '97 C5's are stainless steel. Right?
This is exactly what i'm looking for.
Any others? What about TA's or C6 vettes?
I'm looking for a central exiting exhaust collector. I need to see some pics.
Thanks, Russ
Old 01-02-2010, 02:31 PM
MeanYellowZ's Avatar
97 Vette should get a you center exit flippable, stainless manifold which might provide a decent start to a set of twins if you have a "tall" engine compartment. They do have some EGR tubes on them to deal with. The C6 style manifolds are compact and make a nice flipped manifold as does the CTS-V, but they are cast so you have to build short extensions to adapt from their 2-bolt exit flange to a T3 or T4 style flange.
Here is the early C5 style
and C6 vette
Old 01-02-2010, 02:57 PM
barnat's Avatar
Default E bay
I just saw a pair of 99 corvette manifolds on E Bay for ($45 current bid) if this helps at all? They looks brand new!
Item number: 220531979435
Old 01-02-2010, 03:15 PM
Snyper's Avatar
These are my cast manifolds tigged to mild steel.(welded inside and out)
Old 01-02-2010, 09:12 PM
and C6 vette
Yes! Great info. I've got plenty of room on top of the motor.
I just talked to a buddy about this last night and he has some '98 Fbody stainless manifolds that i'm gonna test fit. If those don't work i'll move to the C5's and C6's. This is EXACTLY what I was looking for. Thanks a lot
Thanks! I'll watch this one.
Nice looking welds. It'd be slick if it was possible to cut the T3 flange off my turbo's and run vbands on the exhaust housing to the manifold's.
I'll have to call around to a couple local shops to see if they have any experience with cast to mild.
This is great, thanks guys.
Old 01-02-2010, 11:18 PM
LS1Tech Sponsor
hellbents10's Avatar
I have welded to the cast manifolds with no troubles at all, many, many miles of street abuse.
Old 01-03-2010, 02:01 AM
Snyper's Avatar
By welding the vbands to my car im able to run the alternator in the stock location as well.
Quick Reply: Are the '98 Fbody manifolds the only "weldable" stock manifolds?
