throwing engine belt with procharger
If you are talking about your engine accessory belt, I went through two rides on the hook just as you described to determine the stock harmonic balancer on a GTO will not handle the added load of a D1SC procharger. Most of the P1SC guys have not had this problem. I had to buy the $400+ aftermarket balancer and I have been free of this problem for a year. Discussed this with Bob at EPP and he said he has seen it many times and it has always been a harmonic balancer replacement which has solved the problem, not the tensioner. I still have the stock belt tensioner.
