Took measurments for belt and cant decide which one to use.
Old 02-11-2010, 04:51 PM
kkslds's Avatar
Default Took measurments for belt and cant decide which one to use.
I have a d1sc with a 3.7 blower pulley. I have a 7.25 crank pulley. With the tensioner all the way up I got 39 1/8" and with the tensioner all the way down I got 40 5/8". Now I have a K080384 and a K080400. Is the 40" gonna be to long after it stretches? I tried to get the shorter one on and couldn't get it. I know their tuff but is it to short or to I need to try harder
Old 02-11-2010, 06:23 PM
kkslds's Avatar
Finally got the smaller one wiggled on there. Now im just having trouble getting all the bolts in. I was able to get one in and got a few threads goin. Then I had to pry up on the headunit with an allen wrench through another bolt hole and was able to get a second one in. After having two of the bottom bolts in, the two top ones (one on each side) still arent lining up. Giving it a break for tonight and will try some more tommorow or saturday. Any tips on getting them things in there with a super tight belt? Thanks
Old 02-11-2010, 06:47 PM
XtremeDime's Avatar
Sounds like the belts is TOO tight, that could cause issues. I would just go get one 1/8" longer or so.
Old 02-11-2010, 07:11 PM
kkslds's Avatar
I called and it goes from the 38.4" to the 40". I have both and according to them (oreilys) there isn't one inbetween
Old 02-11-2010, 07:23 PM
XtremeDime's Avatar
Oreillys is ****, call NAPA and see. I had to go to a specialty shop to get mine.
Old 02-11-2010, 08:04 PM
kkslds's Avatar
I think the closest napa is over an hour away. We dont have any around here
Old 02-12-2010, 07:18 PM
kkslds's Avatar
Tried again and still cant get the other bolts in. Decided its too tight for my likings. Went to gates website and they go straight from 38.5" to 40". I did some more searching and found gatorback makes a 39.25" that I think will be about perfect. Wont be here till Tuesday because of the holiday though
