What vacuum pump do you guys run?
This question obviously goes out to the guys making 4 digit horse power......who run vacuum pumps. I am considering running one this season (maybe next if my car ever gets done ). Which ones work good? How much does the entire set up cost. I'm pretty wet behind the ears with vacuum pumps.
Also, my car will see 10% street duty and I thought I read somewhere vacuum pumps aren;t good for the street. What say you?
I was doing some research and I will prob. run this with my s91 setup. The EXA pump
http://www.turbowerx.com/Scavenge_Pu...nge_Pumps.html
As mentioned earlier in this thread, I also need to figure out how to cram 5lbs more ****.....into a 1 lb bag These twins and a high-mount alternator sure make this difficult!
I met a guy here in detroitwho has a turbo LT1. He hooked up the factory air pump to a pressure switch. then routed the air inlet to one of the valve covers. So now whenever he gets into boost it kicks on. Said hes had zero problems with it
Just saw this up for sale on the parts section. It looks like a full setup and I think its in very good condition. So if you are interested check it out. I think its a good deal, if its not sold yet.
https://ls1tech.com/forums/parts-cla...e-chicago.html
