Alky kit where to put nozzles for best result
Hi all, buying a AIS trunk kit 70% meth 30% water.
Going on my 383TT low mount set up making 700RWHP odd.
Looking a placing a nozzle just in front on the intake pipes before each of the turbos.
In addition i may add a third nozzle 6" infront of the TB.
Would you say this is the best set up a meth kit?
Also do you rate the AIS kit.
cheers
paul
cheers
paul
you need them before the IAT sensor so PCM can read the change in intake temp but after the blowoff valve so you don't spray meth through your engine bay when the blow off valve vents.
I was going to be putting my in front of tb maybe 5 inches. That would be after the iat. I can't possibly put it pre iat or farther away from tb but not overly worried about that location. Also going to be running 50/50 not 100% meth. Don't like things that flammable , 50/50 is safer and supposedly works very good as well.
I fill like a ***. I have been having problems with the car pulling timing due to high intake air temps all summer. I am using aky controll and didnt even think about my IAT senser placement. I am spraying about 6 inches before the TB and my IAT senser is about 6 inches before that
Can you show us where you put it? I am going to relocate mine to the manifold also. I am thinking of placing it where the egr usually is but I have a manifold with no egr so I will be taping into that spot for the IAT sensor. Thanks.
