turbo suggestions please
turbo suggestions please thanks guys
lt1 396 stroker splayed lt1 afr 210cc comp port #1101 victor efi port matched to heads 1206 gasket elbow with 90mm tb je custom -31cc pistons lunati 5.85 forged rods and callies forged crank pro turbo kit just a dump pipe no exhaust 160 lb. Injectors running e85 fuel and a FAST ecu through th400 3800 stall converter bolt 3.73 gears 28" race weight with driver 3400 lbs and 1.6 roller rocker I want max effort 20-25 lbs boost high hp trailered drag car cam spec options (244/247 .664/.664 115) or (242/244 .627/.634 115) or (258/252 .688/.680 115)
how does this turbo sound ?
Specs:
T78 compressor wheel
Ball Bearing / Water cooled
Polished compressor
F1-68 turbine wheel
1.15 T4 Divided tubine housing
3.5 V band added per Turbonetics
Turbo is good for around 1150-1200hp
Specs:
Polished compressor
F1-68 turbine wheel
s480
http://www.theturboforums.com/smf/in...topic=123167.0
IMO, any t4 frame is going to have excessive back pressure on a 396
I did get ahold of jose (forced inductions) well my proturbo kit is a t4 so he suggested the PT88 or the GT88 I know I need a large ar maybe at least 1.15 but not sure waiting on his input he has great prices and warranties too I'm trying to figure what's best out of these two
