Procharger upgrade help
1 Post
I took an M1 Procharger that I had on a boat I used to own and made my own brackets, tensioner,etc to mount it on my LS2 in my '71 Camaro. I'm getting 5psi of boost and of course want more. My crank pulley is 8" diameter and the blower pulley is 4". I've done the math and without going over the maximum impeller speed I can put a 3.5" pulley on the charger. Thing is I'm having trouble finding one. I've found listings for other prochargers, but not the M1.
My second question is, what other procharger uses the same mounting bolt pattern as the M1 so I can consider that as an upgrade?
LS1Tech Sponsor
Is the pulley centered or does it have an offset to it? Nice looking split bumper Camaro, it looks like you did a great job with it! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
1 Post
The pulley is on the centerline of the charger body, from left to right, but is offset lower. It is the oil fed version.(not self contained)
The elbow is unfortunate, but is a full 3" 90deg elbow. It does look small in the picture though.
The M1 is pretty much the exact same blower as the P600b. It's just the marine version. ProCharger makes 2.65", 2.75", 2.85", 2.95", 3.05", 3.15", 3.25", 3.35", 3.45", 3.55", 3.75", and 3.85" 8-rib pulleys for the M1 and P600b.
There are no upgrades for the impeller. The part numbers for the pulleys are DPxxxI-008 xxx being the size. For example, DP265I-008. This only works for the M1 and P600b. P1SC and D1SC pulleys end with -06D or -08D.
I didn't mention the P1200B because they're fairly rare anymore and ProCharger won't build them anymore, but if you could find one, yes, that would work.
1 Post
I couldn't clock the charger any further down as it hits the inner fender. I'll take some detailed pics tomorrow and post them.
I found some specs on my charger. looks the same as the p600b however the maximum impeller speed is 50,000 on the m1 compared to 60,000 on the p600b. all other specs are the same, including step-up. I am using a 8" drive pulley. what compressor pulley should i get?
1 Post
Thanks for the help KS... Ok, I ordered a 3.35" Pulley today as suggested after finding out that my m1 pulley is 3.55" and that my drive pulley is 7.65". I will take another look at my air filter and see if I can improve things there.
