oil return pump proper install info needed
Guru's,
About to install an oil return pump on the TT goat,..and hopefully have it running this weekend. That said... I would need check valves routed in line correct? If so,..where exactly do I put them... after the turbos and before the pump,... or just after the pump. Where do I get these or what do you recommend me using that I could find locally perhaps. This is so we don't suck the turbos dry on start up,..correct?
Only experience I have with oil pumps is when I have installed STS kits... which I believe has a check valve/ball at the end of the oil return line, going into the oil fill cap on valve cover.
Did a quick search... came up with all kinds of oil noise issues.
Thanks for any pics or insight. I appreciate it.
No between the feed and the turbo. On a scavenger set up as u already know the pump returns the oil while the car is running. while the car is of the oil in the line will still flow and fill up the turbo since the turbo sits almost if not level to the pan. A check valve function is when it sees 1 psi of pressure it will open, any car runs between 50-80 psi of oil pressure so no problem of it not opening. So when the car is shut off the flow is cut by the check valve and the oil is stop. a rule of thumb that i did was to run the scavenger pump about 5 sec after shut down to prevent cooking my oil. work for 3+ years and still going.
Thanks man, i'll see if I can search that out.
I still don't understand why a check valve is needed on the supply side. There will be oil sitting in the lines and turbo, but the savaging and lubricating process starts again when the engine fires. The install on the STS might be to keep the system from oil starvation on initial start up?
A car with a return pump needs a check valve at the turbo on the feed line. You would be suprised how long that feed line continues to push oil after the key is turned off. If a guy had a place for that large volume of oil to drain post turbo it would not be needed. You could have the return pump run for 15 seconds after the key has been turned off but it isnt too great on the pump to be moving such a low volume of fluid. Check valves for the fix.
Ok, but we are talking about a closed system. The oil goes to the turbo or supercharger and out to the pump which returns it to the motor. So if the oil continues to flow, it will fill the available space, turbo, hoses, and then stop. The pressure will never be as great as operating oil pressure. What am I missing?
I had to run check valves on my pressure and suction side because my oil tank is higher than my turbo's and the oil lines were back-flowing oil and filling up the turbo's when both turbowerx pumps were off (dumping oil out the exhaust pipes upon startup). I bought my check valves from the big catalog guys... sum**t
