Virginia Speed 427,Mast LS3's and a TVS2300(updated-901bhp)
Old 05-07-2010, 08:21 PM
Shawn @ VA Speed's Avatar
Default Virginia Speed 427,Mast LS3's and a TVS2300(updated-901bhp)
Here's a rundown of this project
Virginia Speed sleeved ls2 block 4.125 bore
Callies Compstar crank and rods
Wiseco pistons and rings
Mast big bore LS3 heads
custom cam
Magnacharger TVS2300 for ls3 heads with 10 rib pulley setup
We're heading to the engine dyno in the next week or so.Hopefully we can squeeze 900hp out of this bad boy on pump gas.Stay tuned.
Old 05-07-2010, 09:28 PM
FL-Pirate's Avatar
Looks awesome Shawn. Can't wait to see the results.
Old 05-07-2010, 09:40 PM
elias_799's Avatar
what CR ?
if you do not mind me asking
Old 05-07-2010, 10:31 PM
LS1RedZ's Avatar
Wow. Thats bad ***!! Gonna be a torque monster!
Old 05-08-2010, 07:12 AM
OUTLAWZ RACING's Avatar
Love the pink injectors lol, Nasty build tho.
Old 05-08-2010, 07:48 AM
wkdivr's Avatar
Interesting build! Looks like it's going into a TBSS. Yes? Sent you a PM.
Old 05-08-2010, 10:07 AM
7 Second Club
Phil99vette's Avatar
Badass motor for sure!
Old 05-08-2010, 10:23 AM
HEAVY_CHEVY's Avatar
Bad ***!. Definitely going into a TBSS. The front sumped swiss cheese oil pan gives it away. Need a better pan solution for the AWD trucks, moroso has a pan for the 2wd already, and with some modification to the subframe a c6 pan fits on 2wd models too.
Old 05-08-2010, 12:42 PM
427's Avatar
That supercharger will be killer in a street truck! Shawn, how does the intercooler look on that intake? Can you get iat numbers under the intercooler in that intake?
Kurt
Old 05-08-2010, 02:13 PM
C4 Silver Guy's Avatar
Boy, that's beautiful!
Old 05-08-2010, 05:20 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'll have to show my friend with a TBSS this link. He should **** himself.
Old 05-08-2010, 06:01 PM
Ericmck2000's Avatar
Wow, i was in virginia beach earlier today. Too bad i didnt stop by and see that beast.
Old 05-08-2010, 07:21 PM
beavis's Avatar
Shawn how do you like the Mast Motorsports heads? I've got a set of there big bore heads about to go on a 427 also.
Old 05-08-2010, 08:03 PM
we did a lot of modifications to the oil pan.If you look-the oil filter has been removed from the pan and it will be run with a remote filter.The AWD pan definently leaves alot to be desired but the mods we made,make them a ton better.
Kurt
Kurt,the ic setup leaves a little to be desired as usual on these things-the iat is after the initercooler.
BTW-i still need those fittings-just forgot to call last week,i'll get up with you this week.
The Mast heads are great.They are made by Performance Inductions so it's really a no brainer for me as we use a ton of their stuff with great results.
Old 05-09-2010, 11:57 AM
Denali08's Avatar
How much boost do you plan on running?
Awasome setup.
Old 05-09-2010, 01:42 PM
I see. I know that RPM has modified oil pans for the AWD trucks in the past, and also offer what they called a "side oiler kit". Blocking off the OEM oil filter and using the oil galley plugs in the side of the block for improved flow.
I love launching hard and watching the oil pressure drop to 20psi on my truck!
Old 05-09-2010, 07:58 PM
LS1Tech Sponsor
Slowhawk's Avatar
Screw the HP , I want to see the torque.
Old 05-09-2010, 08:49 PM
tom's2005gto's Avatar
sounds very familiar! subscribing for numbers
Old 05-09-2010, 09:50 PM
elias_799's Avatar
buy a diesel then
Old 05-10-2010, 06:14 AM
Fireball's Avatar
looks good as usual....looks like your engine room is pretty full
Quick Reply: Virginia Speed 427,Mast LS3's and a TVS2300(updated-901bhp)
