Wondering about a stock LQ4 LQ9 under boost
Old 05-14-2010, 12:00 PM
The Fugitive's Avatar
Question Wondering about a stock LQ4 LQ9 under boost
okay so I have seen the threads on how a stock LS1 (bottom end) and 5.3 would hold up/live under FI. Now I would like to know about the stock iron blocks (LQ4/LQ9) have lived under boost. I have one that has a approx CR of 8.8 and I am only on 5#'s and looking to go higher. So I want to see if anyone has tried this and what limit they got to. So I would like to see what FI you went with, CR, how long it lived from install, HP/TQ, if you broke it & most importantly how you drive the car. We might as well know what all LS type blocks are capable of. Think of this kinda like knowing how much HP you can run knowing you're close to breaking that stock 10-bolt.
Old 05-14-2010, 12:16 PM
Restricted User
98Z28CobraKiller's Avatar
My stock longblock let go at 6500 RPM and 15 psi.
Old 05-14-2010, 12:19 PM
nitr0racing21's Avatar
holy **** thats alot of boost for stock!
Old 05-14-2010, 01:13 PM
Restricted User
It was on 15 psi for a good while also. What killed it was when I raised the rev limiter over 6K. 2nd pass @ over 6K RPM it put a rod out the side of the block. I was running consistant 10.0's @ 130ish but couldn't make it to the traps with my gearing (3.73's at the time). Was coasting thru on every pass. Finally I had all the bugs worked out and was ready to forge the bottom end so I went out with the intentions of running a 9 or blowing up. It ran like a 10.005 or something on the pass that it let go but it broke before the finish line. I had intended to just blow it up but I ended up blow it apart.
Old 05-14-2010, 01:18 PM
so not to thread jack but you ran 15 PSI on a bone stock LQ9 block? what did it dyno?
Old 05-14-2010, 01:19 PM
mdbreaux's Avatar
My 6.0 iron block lifted the heads with only about 14 psi boost and 8.5 compression Wiseco dish pistons. What happened is that two ARP studs pulled the threads out of the block. I had copper head gaskets and o-ringed heads. I dicsovered that this is common. I ended up buying a LS2 ERL Performance 427 ci block and am using 6 bolt Trick Flow heads from Total Engine Airflow with 1/2" main studs and 3/8" 5th and 6th studs. I am running double o-rings now cut in the head and block. I also expect to run up to 30 psi on race fuel.
Old 05-14-2010, 01:21 PM
Restricted User
I dont like dynos. My car hasn't been on a dyno in years. I do testing and tuning at the track where it matters.
The following users liked this post:
fastfreddy77 (10-10-2019)
Old 05-14-2010, 03:12 PM
MaxxMitchell's Avatar
My stock lq4 with ls6 springs and pushrods put down 623 at 15lbs and 16 deg of timing on e85. I drive it like I stole it, and have for the last 4500 miles. It did push water at anything over 13.5 lbs. I switched to a gt2-3 cam, patriot duals,ls9 gaskets, and studs and so far haven't pushed any water.
Old 05-15-2010, 03:42 AM
wow you guys are doing some big things with the stock motor. Whew okay it seems as though if I want to run it keeping it at 12lbs would be fine. I feel like a giddy school girl cause parts are on the way.
Old 05-15-2010, 09:24 AM
LS1Tech Sponsor
hellbents10's Avatar
Stock LQ9
825rwhp/847rwtq
E85
4000lb 05' GTO, 80e, stock 17s with 275/40 et street raidails 9.91@141
5k miles like this.
Old 05-15-2010, 10:35 AM
87silverbullet's Avatar
Originally Posted by hellbents10
Stock LQ9
825rwhp/847rwtq
E85
5k miles like this.
Everytime I see you post about this it never seems to stop amazing me. This is just sick!
Old 05-16-2010, 08:21 PM
Stock LQ9
825rwhp/847rwtq
E85
5k miles like this.
how do you drive it? And how much do you take it out?
Old 05-17-2010, 07:28 AM
LS1Tech Sponsor
He drives up to our shop alot from his house about 30 miles away. He pretty much pulls it out and makes pulls on it all day, takes people for rides and puts it away. It is driven often in between broken transmissions and such.
Old 05-17-2010, 10:05 AM
RS_SS69's Avatar
Stock LQ9
825rwhp/847rwtq
E85
5k miles like this.
What turbo are you running on this setup?
Old 05-17-2010, 11:07 AM
MY99TAWS6's Avatar
I have seen tons and tons of cars on here with built 6.0 iron blocks running way higher than your boost level up to 20psi and not using any fancy oringing just arp head studs the normal ones and normal head gaskets. You must have detonated that thing huge to do what you did at only 14psi. Its not boost that lifts heads its detonation.
Old 05-17-2010, 11:27 AM
tirefryin_s10's Avatar
800 ish rwhp here.
14 psi
Twin T70 turbos
Stock pistons
Stock rods with arp bolts
Stock Crank
Stock main bolts
Stock bearings
Stock rings
Custom grind comp cam
Stock timing set
Stock oil pump
Comp 850-16 lifters(stock replacement)
ported 317 heads
94 octane pump gas/meth
Regularly saw the 7200 rpm rev limiter.
No pushed water. 9.51@147 with a shitty 60 foot, LOTS of street miles/pulls.
Its all in the tune up, they do NOT like timing and they like to be a little fat.
Old 05-17-2010, 12:24 PM
pwrtrip75's Avatar
You have a stock one with 8.8 compression? How did you get that? I just rebuilt a stock LQ4 and i looked it up and it said the compression was 9.4 and i think an LQ9 is higher. right? Im guessing mine is an LQ4 by the dished pistons, I think LQ9s are flat.
Old 05-17-2010, 01:19 PM
I bought some 317's that had some work on them from TEA so the chambers are 79cc
Old 05-17-2010, 02:05 PM
danbap's Avatar
Originally Posted by tirefryin_s10
800 ish rwhp here.
how much timing are you running? what is your a/f at WOT??
Old 05-19-2010, 05:42 PM
pwrtrip75's Avatar
Originally Posted by danbap
how much timing are you running? What is your a/f at wot??
x2 ??
Quick Reply: Wondering about a stock LQ4 LQ9 under boost
