Post up your turbocharged engine bay!
Well the rear mount was basically simply for looks! But your a little wrong, the intercooler actually works quite well, even with a 0-100+ mph 18psi pull the IAT stays right with ambient temp outside!! Also after hard pull I have stopped and used a infered temp gun on both the inlet and outlet of the intercooler and there is always a 20-30 degrees difference!
Its the aeromotive boost referenced regulator, it does have an -8 line for the return only because I had enough -8an line to go from the tank to the engine and back, the return port is actually a -6an hole with a -6 male to -8 male adapter!
Actually I still have some lines and wiring to finish before the swap is complete. But I'm sure when it is done, it probably will have a lot more in it without the filter. But its the biggest diamter one I could find to fit in that small of an area. The filter has a 6" inlet. I guess we will see.
Great setup bro. looks sharp.
