procharger guys what filter are you using????
id like to see what intake filters you guys with prochargers are using.
i know that the type, style, and location of the air filters will affect performance so i would like to see what were you using and what are you using now and what your results were/are.
The following users liked this post:
fucter (11-21-2022)
i run the stock size filter on the street..or on the street during "normal" driving and the HKS mushroom looking filter filter with a filter on bypass for "spirited" driving..
Inlet on what is 3.5"? if you are referring to the D1SC, its actually 3.75"
http://www.dallasperformance.com/DPC...lter/index.htm
bump. i picked up 4 psi on the dyno with my filter off. i have to find a better flowing filter. going on to my d1sc ive been thinking about running something that has a 5" opening and just stepping down right at the inlet.
This is what I'm using, I saw a gain 1.5 #'s of boost.
Procharger supplied filter on the left new filer on the right. http://mycarpics.shutterfly.com/276
K/N # for big filter ^^^ http://www.knfilters.com/search/prod...x?Prod=RF-1045
Added this little filter for the bypass hole. I had a frost plug in that hole to start. http://mycarpics.shutterfly.com/277
K/N # for the small filter ^^^ http://www.knfilters.com/search/prod...x?Prod=RU-0200
