TWIn .57mm 18*@14lbs
http://www.youtube.com/watch?v=fOj-FBoYJl0
STOCK HEADS, CAM, AND INTAKE MANIFOLD @ 71% DC
72LBS INJ, 255 WALBRO, AND BAP
HI-FLO CATS, SPINTECH X PIPE AND MUFFLERS
RACE GAS MAP SOON!!
RACE GAS MAP SOON!!
Single walbro and no meth? 14lbs of boost on a an engine with 11:1 compression and running 18 degrees of timing... Doesn't add up at all.
Edit: How many times did you burn #7 down?
PerformanceModifications:Garrett TwinTUrbo .57mil/TwinTial WG's&BOV's/72lb'ers/Walbro 255/Kenny Bell BAP/HpTUners/2bar/mAf deLete spEEd DenSity/AEM Meth kit/AEM WIde Band/AEM BoOst/KOoks CaTs/SPinTeCh cAtbaCK...365c.i. forged block, shaved heads(.14), cometic gaskets(.40), steel top rings, aRp head/main studs, Eagle Rods, Diamond-13.7 dished pistons, klevits bearings, IN-motion double row timing chain, Pac valve springs, Performace grind stock crank
my goal is to max out my fuel on the stock cam and heads first.. id like to see 850 on race gas. then i will go with some AFR heads and boost cam prolly a 220/226 ... more or less since its a dd
