Not making boost? Check this out...
Old 07-08-2010, 04:25 PM
rjparth's Avatar
Default Not making boost? Check this out...
Since I had so freaking many after I bought my supercharged SS and took it in for a "once over", I figured I'd share my list 'o leaks. Maybe it will help someone else pinpoint a leak.
PCV Valve - boost was leaking into the crankcase.
EGR Gasket - the 98-99 LS1 intake manifold has 1 bolt on the EGR causing it to rock under boost and leak.
FMIC - The procharger air intercooler was leaking from the place they stamped their logo into the aluminum. The stamping pushed too far and created pinhole leaks.
T-connector - A regular T evidently doesn't cut it. It works for vacuum, but it will leak boost. It was replaced with copper compression fitting.
Couplers - Not really a leak, but it was identified as a restriction because the pieces were pushed too far into the coupler.
Hope it helps!
Old 07-08-2010, 04:57 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Hope it helps!
I have seen this happen before. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 07-08-2010, 05:01 PM
XtremeDime's Avatar
I dont understand what youre meaning about the couplers.
Old 07-08-2010, 05:05 PM
Restricted User
98Z28CobraKiller's Avatar
I'm guessing that they are talking about the 90 and 45* couplers. If you push the pipe too deep it will get in the bend and block part of the air stream.
Old 07-08-2010, 05:07 PM
XtremeDime's Avatar
Ahhh ok, that makes sense!
Old 07-08-2010, 06:58 PM
rjparth's Avatar
Yup - that's it!
