Choosing twins for 5.3L?
Old 07-17-2010, 06:22 AM
mgroshong's Avatar
Default Choosing twins for 5.3L?
Ok, i see there's a similar thread up but i didn't think i should jack it with my questions.
Well this is my first time dealing with a v8 so bare with me on this guys. I have done quite a bit of searching and haven't found a thread that gave me a definitive answer to my questions.
I'm going to be running a relatively stock 5.3L with pistons and rods only. I have decided i want a pump gas only set up so all my goals/use will be on straight 91 octane. so with that in mind i think 8:0-8.5:1 comp will be safe enough to allow some good power on 91. I will be running a manual trans but have not narrowed it down yet to which one.
goals:
- street car with occasional track days. (4-5/yr)
- 600whp (reasonable?)
- fast spool (not instant, but minimal lag)
- NOT a drag set up
Now I'm going for a bottom mount setup in a c4 corvette so fitment is tight. and with me on a modest budget BB/GT series turbo's are out of the budget. so with that said I'm thinking t3/to4e or maybe with a to4b cover.
I'm thinking a t3/t04e 50 trim stg3 .63a/r might work but I'm clueless on v8's and there turbine needs. (used to Honda's don't kill me) I haven't seen much talk on turbine sizing with twins. So??
So do you guys think the 50 trims will let me reach my goal?
Do you think i would lose to much flow if i had to run a to4b cover vs. the to4e?
Do i need to run a larger turbine housing?
Old 07-17-2010, 05:27 PM
mgroshong's Avatar
Anyone?
Old 07-18-2010, 12:08 AM
TurboS10's Avatar
don't use compressor trim in the v8 world. Just wheel size. Trim is only for the custom big wheel small housing stuff.
But I'd assume 50trim is way to small. LS motors move some air unlike older V8's.
Just as an example, guys are running single 76-78 mm on rod bolt, z06 cam stockers.
I'd go with a 58-61mm compressor and the biggest t3 you can get.
It will be near instant boost anyway with the small housings.
isn't a stg 3 a t3 ptrim?
small exh means low rpm, small stock cam, 5500 shift.
8-1 will be too low and probably need custom pistons.
Lots of guys running 9-1 at your power goal.
Cam selection will depend on what turbines you run and CR.
What car you building?
Old 07-18-2010, 12:26 AM
mgroshong's Avatar
Ok, yeah I'm learning the different terminology slowly. ha
These would be 54mm turbo's. I had thought of maybe running s256's but the Garrett's have better housing selection in the smaller stuff.
the stg3 is a 65mm-56.61mm in/ex the p trim T4 is 74.2mm-64.6mm.
So there are no durability issues with 9:1? I really don't feel like freshening this up every year, kinda just want to build it once and on the safe side.
A friend offered me a comp cam 54-412-11 with 212/218 and 114 lobe separation. He said it was a mild cam and that's what i have gathered.
The car is a c4 corvette, I'm still in the planning stage and gathering the parts.
Old 07-18-2010, 12:41 AM
TurboS10's Avatar
The 65mm threw me.
I'm looking at that same cam.
You know you can bore a 5.3 to a 5.7 bore and be fine usually on wall thickness?
You end up with an iron 347. - 3.622 x 3.905
That's my plan with 2 T4 ptrim .68 T61's.
With a stick I'd go with the .58 ar or SC61's which come with a t3 ptrim setup.
I got my 58mm practice turbo's almost new and cheap because they went to small on an LS1. They thought it was the 2.75 inlet T04x housing. I think it was the ptrim .58 OC housings backing up the exhaust.
Check this out.
https://ls1tech.com/forums/forced-in...ame-motor.html
Old 07-18-2010, 01:02 AM
mgroshong's Avatar
The 65mm threw me.
What are your thoughts on it with F/I? This may be a question for another thread however.
You know you can bore a 5.3 to a 5.7 bore and be fine usually on wall thickness?You end up with an iron 347. - 3.622 x 3.905
Yeah, i know you can bore these. I decided on the 5.3 for durability reasons. I figured the drop in displacement would be more then made up by the turbo's.
Check this out.
wow those are some big turbo's. Crazy the engines can spool those things.
Old 07-18-2010, 03:02 PM
mgroshong's Avatar
Come on guys, lets hear what you think?
Old 07-18-2010, 03:07 PM
Coal Mining Director
onfire's Avatar
GT3582R's with a 63 turbine ar.
Old 07-18-2010, 04:51 PM
mgroshong's Avatar
I just can't afford $2600 in turbo's.
Old 07-18-2010, 04:52 PM
stoopid john's Avatar
I've got two mp 70's with .68ar. I was planning to do a 6.0 but found a 5.3 for $175 with 90k on it. I'm going to give it a try, need to pick the right cam and this too will be a street car most of the time. When it breaks or doesn't work i'll use the engine and go out to a 5.7.
john
Old 07-19-2010, 12:10 PM
IT_SS's Avatar
i was spec'd T'netices TC66-65's with .58 exhaust AR by Forced Inductions, give em a call
Old 07-19-2010, 12:20 PM
Marcello7x's Avatar
If cost is an issuse, you might want to go with ebay turbos. Im starting to contemplate them. Godspeed has come out with turbos now, and have read revies about there otherstuff being prety good. I thing i read that one board member here has run a godspeed for over a year with no problems.
Old 07-19-2010, 04:21 PM
mgroshong's Avatar
Those seem a little big for a street car to me. Hows the spool on them with a manual? i have been trying to stay with the T3 turbines for packaging so idk if those would work.
I have a few friends running the ebay turbo's and haven't had issues. but idk they just seem like a crap shoot plus no one really can tell you what the specs are it seems.
Anyone have more info on t3 based turbo's?
Old 07-19-2010, 04:27 PM
elias_799's Avatar
i would go with twin turbonetics tc61's ball bearing
Old 07-19-2010, 04:46 PM
chevybowtie's Avatar
I'm going with TO4S 58mm turbos for my 5.3 twin build. I'm looking for 650-700HP.
Old 07-19-2010, 04:51 PM
mgroshong's Avatar
How large are these turbo's? do they use the to4e or to4b housings?
Old 07-19-2010, 04:54 PM
S housings. They have a 4" inlet with 2.5" outlets. They are the biggest T04 housing you can get.
Old 07-19-2010, 04:59 PM
mgroshong's Avatar
I doubt they will fit, you have to remember this is going on a bottom mount set up in a c4 corvette. I just don't see me fitting the s covers. 4" inlet no way.
Old 07-19-2010, 05:05 PM
elias_799's Avatar
they fit in my f body
Old 07-19-2010, 05:08 PM
You don't have to get them in the T04S housing. They also come in T04E's too. You have many options.... I would stick with 58-61mm twins for what you want.
Quick Reply: Choosing twins for 5.3L?
