what the best spark plug ? 18 psi
Hi i want to know what the best spark plug for my engine ( 408ci , 9.1 cr , 18 psi ) ???
TR6 = ?? gap
TR7 = ?? gap
TR8 = ?? gap
thanks
navy
TR6 = ?? gap
TR7 = ?? gap
TR8 = ?? gap
thanks
navy
7 Second Club
Just because you can get away with running a 6 heat range doesn't mean it's a good idea at that power level.
I would run an 8 heat range plug with the ops combo. I run the Autolite AR94s since it's still a tapered seat plug for the AFRs but they don't last long with the cut back strap. I believe the 3911s are gasket seat and not sure how well those will work with AFR/stock style heads.
ive ran TR6 at a dyno'd 700 rwhp with a pt88 and i also ran the Tr6 at 20 psi around 800 rwhp with no issues and 23* timing on 93 octane. no issues what so ever, this was on a 4.8
to the OP, what size turbo? what compression? what grade fuel, what motor size all play a role in plug choice
Restricted User
You are missing the point. We aren't talking about spending several thousands of dollars or paying thousands in labor to change them. We are talking $18 in plugs and 30 min. It's the cheapest insurance you can buy in this game. It's not like you'll lose any power. Why risk it?
re plug
