Pinning front of crank?
Was about to pin the front of my balancer/crank, however it doesn't appear that there is enough room for the drill? The bit alone barely has enough clearance. Only thing I could think of is getting a angle driver, however I don't expect that to give me enough leverage. Anyone chime in who's installed one this way?
*Plenty of write ups on pinning the ATI balancer, but this is for the 6-rib setup, not the 8-rib where you pin it at the side.
Closed ex-Sponsor Account
We use a 90* drill on the cars that we can not get a regular drill in. Takes a little extra time, but it will get you there.
Hope this helps-
Zach
Hope this helps-
Zach
You didnt say you still had all the parts in the car. Had front end noise out of the car. I still wouldnt want to do it with the 90 deg drill. That **** is hard to drill.
