Best Turbo Route for 7s?
Old 08-05-2010, 07:54 AM
dreamls1's Avatar
Default Best Turbo Route for 7s?
In the process of planing our next years build. Plans are to run in the 7s with a "street car" (although i dont drive it on the street). My Engine is going to be a 408 and 91mm. But i got to thinking, would it be better to run twin turbos? I know its going to cost more, i just want to have a powerfull efficent car. Any input to get me in the 7s would be great. I am running a th400 trans.
Old 08-05-2010, 08:08 AM
venom ws7's Avatar
98mm..
Fireball ran 7.9 with that turbo and small LS2 364ci ..
But if you want mid 7s then 106
Old 08-05-2010, 08:15 AM
Restricted User
98Z28CobraKiller's Avatar
Your first problem with running a big single capable of 7 sec passes is packaging. Specially if you want it to appear to be a strweet car. Packaging presents 2 problems. The first being the actual thumper itself and the second being the 5" DP that you have to get out of the engine compartment.
I don't think that the 408 w/ 91mm combo would get you there unless you plan on being sub 3K# anyway. We got LS2Formula JUST into the 7's so far and that's with twin TC78's at 3500#'s. Much easier to package the twins.
Old 08-05-2010, 10:13 AM
LS1TECH Sponsor
DrTurbo's Avatar
Give us a call we can help with the setups. Twin or single can be done....just depends on room
Old 08-05-2010, 10:30 AM
Loudmouth LS1's Avatar
I would say you would have to up that to at least a 98mm for 7's. I personally prefer a big single, less maintenance and initial cost. I'm going 106 on mine, but i'm just putting the downpipe right out the fender since I don't really care about the whole street car look and i'm shooting for bottom 7's, but if you couldn't fit a 5" dp past the kmember you could always split to dual 3" to get it back there.
Old 08-05-2010, 10:51 AM
Fireball's Avatar
step one...ditch the T400
Old 08-05-2010, 11:05 AM
dreamls1's Avatar
I was waiting for that .... You don't think th400 can run 7s?
Old 08-05-2010, 11:07 AM
Shawn @ VA Speed's Avatar
A Precision Pro Mod 94 will get you in the 7's with the right combination-this is probably the smallest single capable of it.The physical size is a little smaller than a gt4788.A pair of 76's would easily do it as well.Your going to need a very well built engine and def would scrap the th400.
Old 08-05-2010, 11:21 AM
Depending on what's done to it it could hold, but that 2.44 first gear will make life harder with the launch, I personally am a glide guy ever since I swapped to the glide from a t400 and picked up 2 tenths and 2 mph! But a good glide or a th210 will do the trick.
Old 08-05-2010, 11:57 AM
helicoil's Avatar
Plus one on the Rossler TH210XHD.
Old 08-05-2010, 12:57 PM
dreamls1's Avatar
Didn't vette dr run low 8s with a th400?
Old 08-05-2010, 01:00 PM
Zombie's Avatar
Why do you want a non "street car" "street car". Doesn't really make much sense. Are you just trying to avoid the race car look?
"street car" often means heavy too.
Old 08-05-2010, 01:04 PM
dreamls1's Avatar
Sorry, I mean street trim, don't care what it looks like. NMCA true street is what I mean
Old 08-05-2010, 01:16 PM
1INSANEGTO's Avatar
Glide + gearvendors.
Old 08-05-2010, 01:17 PM
Gingervitis Addict
slow67's Avatar
There are many other gearsets (besides stock 2.48 and 2.10) for Th400s. And there are also many other reputable trans builders besides Rossler.
Old 08-05-2010, 01:46 PM
Fireball's Avatar
T400 are limited to stock cases...I like the aftermarket support for PG...
I know Phil and I both run ATI trannys...
Old 08-05-2010, 02:28 PM
LS1TECH Sponsor
DrTurbo's Avatar
A 91mm can do it with the right combo and right wheel.
91mm EXT-R should fit the bill....
Old 08-05-2010, 02:58 PM
Firechikn's Avatar
Damn. I need an upgrade. How much more can that wheel support over the ett wheel?
Old 08-05-2010, 03:08 PM
dreamls1's Avatar
Thanks Doc. What does that thing max on at? Who makes the 91mm EXT-R? price?
Old 08-05-2010, 03:13 PM
LS1TECH Sponsor
DrTurbo's Avatar
EXT-R wheel flows 10% more. . They are 11 primary blade CW's, no secondary blades. Higher pressure, and more flow at lower shaft speeds. Also the wheels are 40-50grams lighter due to slimmed hub line and thinner blades as well as total blade count is less 10% minimum.
Quick Reply: Best Turbo Route for 7s?
