Rear mount on stock 5.3l
Old 08-09-2010, 06:47 PM
87Lt1Monte's Avatar
Default Rear mount on stock 5.3l
I have a stock silverado . I'm looking to do a rear mount turbo with a fmic. My question is what will I have to do to the motor to run about 10 psi boost. This is for a daily driver and I won't be running that much boost all the time. Thanks for the help in advance. Also I'm probably going to piece together my own kit what kind of oil pump are you guys using. And what size injectors will I need, I was looking at 60's
Old 08-09-2010, 06:50 PM
JAX04's Avatar
valve springs and upgraded rod bolts and let her eat! Also, get some 60lb injectors and a walbro 255, and all the other turbo **** required i run the shurflo pump
Old 08-10-2010, 05:55 PM
87Lt1Monte's Avatar
What do you guys think a 60mm turbo would do on a stock 5.3 ?
Old 08-10-2010, 05:58 PM
JAX04's Avatar
Any more specs on Turbo?
Old 08-11-2010, 09:37 AM
87Lt1Monte's Avatar
I don't have a turbo yet but I'm trying to figure out if a 60mm turbo would be enough to give me about 8 psi boost ?
Old 08-11-2010, 09:57 AM
TurboAv's Avatar
I had an STS kit on my Avalance(5.3l) with a GT35 ball bearing turbo that I ran at 7psi on low boost and 12psi on high boost with meth injection.
Old 08-11-2010, 03:35 PM
87Lt1Monte's Avatar
What kind of power were you seeing on low boost?
Old 08-11-2010, 07:08 PM
TurboAv's Avatar
I still had the stock exhaust manifolds and cats on the car. If I remember correct I was around 360ish rwhp on low boost. It was almost six years ago and my memory is failing. Pretty soon I'm going to be drooling on myself going vroom vroom and powershifting in my rocking chair...
Quick Reply: Rear mount on stock 5.3l
