Underhood temps of 170-180F - normal??
Old 08-11-2010, 10:33 AM
Vetal's Avatar
Default Underhood temps of 170-180F - normal??
I have problem with PS fluid leaking somewhere nad was told it was because it boils. I have front-mount truck mani setup, for now everything is uncoated. I put IAT sensor to the PS reservoir, above driver side manifold, and after idling for some 10 minutes it was reading 175F (with 75F outside temperature). Is this normal, or should I do smth. immediately?
Old 08-11-2010, 03:38 PM
Nitroused383's Avatar
Throw a turbo blanket on it, that should help alot.
Old 08-11-2010, 04:16 PM
robert miller's Avatar
Default ttt
I agree with above guy that is to hot man for that to be that hot for over time...
Old 08-11-2010, 04:21 PM
Restricted User
98Z28CobraKiller's Avatar
I don't think that is crazy high at all.
Old 08-11-2010, 06:53 PM
Vetal's Avatar
I would gladly do that... And I ordered turbo blanket more than 2 years ago from DrTurbo, and I still don't have neither blanket nor my money...
Actually I was surprised to see that there is no path for hot air to escape from under hood whatsoever :O that's crazy. In the back the hood (TransAm) is sealed to the plastic panel, no wonder underhood temps are almost the same as my water temps :o
I think I will a) remove rubber that seals the hood at the back b) wrap pipes and headers
We'll see how much that will help, for the start
Old 08-11-2010, 10:50 PM
black98ws6ta's Avatar
Definately wrap the hotside...that will help just as much as the blanket.
Old 08-12-2010, 01:24 AM
Vetal's Avatar
what are good solutions to provide escape path for the hot air? except removing rubber seal
Old 08-12-2010, 08:25 AM
Super Slow SS's Avatar
I wouldn't remove that rubber seal, I agree that there needs to be a good path for air to escape especially while driving, but I had a friend who removed that seal and every time it rains he has a new problem, water pools under the hood on the intake and he keeps shorting things out.
Old 08-12-2010, 08:28 AM
Vetal's Avatar
good point... if the water is stopped by this rubber and gets to the sides, then I think small 5mm rubber could be used to still direct water sideways but not seal to the hood
Old 08-12-2010, 10:18 AM
chuntington101's Avatar
there is high presure air at the rear of the hood beofre the screen. you are best geting an extractor hood or fitting some vents to your hood and mount them nearer the front.
First thing would be to control the heat under there and then investigate way to remove any heat thats left over. Also might be worth looking at covering the cold side piping with some reflective tape or something. ight help reduce the amount of heat getting back into the intake air.....
Chris.
Old 08-12-2010, 10:29 AM
Vetal's Avatar
hood has some 2" ~vertical plane at the back, I think cutting vents there would allow good escape path without worries about rain getting to the engine will take a look today
Old 08-16-2010, 07:43 AM
As said above i believe that the there is higher presure at the rear of the hood! so putting any form of vent in there would just let more air in the engine bay.....
you are better to remove the heat closer to the front of the hood. also there is strong airflow over that section which should help 'pull' the hot air out of the engine bay.
Just my thoughts.
Chris.
Old 08-16-2010, 07:52 AM
Vetal's Avatar
Hm, need to check that... need to build water manometer I guess
Quick Reply: Underhood temps of 170-180F - normal??
