what are you guys using for feed line
Old 09-28-2010, 06:19 PM
FasTimeSS's Avatar
Default what are you guys using for feed line
I have steal braided line and it keeps popping off and spewing oil everywhere i got the -4 and the fitting seem to fit but my motor is making well over 80psi at wot so thats where it pops please help should i just call nitro daves and have him make me a 10' -4 line?!?!
Old 09-28-2010, 06:39 PM
TX RED's Avatar
what do you mean by popping off?
Old 09-28-2010, 07:11 PM
MUSTANGBRKR02's Avatar
What kit do you have? I have a few nice 4 AN lines that are set up for truck manifold kits or with the turbos in that area. They also have heat shielding around them.
Old 09-28-2010, 07:29 PM
HydroStream6's Avatar
LS1Tech 10 Year
Uhh braided stainless lines hold over 1000psi in nitrous applications. You have something else going on...
I use a 3AN stainless braided feed and a 5/8" drain.
Old 09-28-2010, 07:30 PM
LS1Tech 10 Year
I got my lines from Modular Turbo btw. He's a sponsor.
Old 09-28-2010, 08:38 PM
FastKat's Avatar
I don't know what your setup looks like, but if your turbo is hard-mounted to your exhaust manifolds, you could probably use a piece of steel tube instead of flexible hose.
Old 09-29-2010, 11:39 AM
FasTimeSS's Avatar
its just summit steel braided line where u make ur own ends with the fittings and install them well the rubber hose keeps poppin off the -4 female connection
Old 09-29-2010, 12:11 PM
XtremeDime's Avatar
Sounds like you dont know how to put hose ends on.
Old 09-29-2010, 02:14 PM
TX RED's Avatar
Quick Reply: what are you guys using for feed line
