info on turbo porting?
I was curious to see what the pros and cons were (since my turbo is on my dresser lol) a search pulled up zero. im looking for any and all info on porting a turbo, specifically a TC76.
I know how to port and polish so i was gonna to do it but with such an expensive piece my smarter side said "do a little research first dumbass "
if you cant find anything with just a quick search, then its probly not very good idea to do it? it sounds like your waiting around for parts or time or money to finish your build and your finding other crazy idea's lol i do it all the time.
im workin on my setup every weekend. and still finding other crazy idea's LMAO but looking at this thing it wouldnt take long at all, maybe 2 or 3 hours tops. im just looking for whats possible with it, i.e. power gains, spool benefits, etc.
Turbos are precision machines. I personally would not touch them unless there was obvious casting marks or the flanges didn't match up. Wrap your manifolds if you want something to do. (Longevity might be compromised for very minimal gains). Water injection can cool the boost and give you a bit more power too, spray further upstream (not before the turbine) to give the water a chance to evaporate and cool the charge. The problem is water will collect in your intercooler and every low point. Turbo inlets are often ignored, a poor flowing intake/air filter will hurt you just as much as it would on a n/a engine.
Well. If you want a big project for 5hp. Take your motor apart and apply oil shedding coatings to the inside, deburr everything, coat your exhaust ports with high temp ceramic. Could be done for $20, and header wrap is not exactly expensive. Or yank your power steering, a/c off, alternator. Easy 10 there. But you would need a new belt...
Just saying. I don't know much about turbos.
this guy obviously hasnt bought wrapping lately. I've got a few hundred bucks in wrap in my turbo kit
I wanna know about porting a turbo, facts and experience, nothing more nothing less.
I wouldn't bother doing any more than knock down any rough spots and casting flash.
I'm sure you could go crazy and do a full port job on the housings, but I can't see any real HP gain. If you have time to kill then go for it, just stay away from the inner most ID by the turbine wheel. The gap between that part of the housing and the wheel is critical. Same goes for the compressor side.
I touched up my turbine sides a little, but I was primarily concerned with casting flash breaking up and finding its way into the magic spinny thingy, LOL....
Spend the time you saved drinking a few beers and cleaning up the garage...
Jim
Jim
Im pretty positive the area of the hot side between the flange and turbine is a specific shape so ill just polish it smooth for higher velocity/faster better spool. the compressor discharge i think will benefit from mild porting and a very good polish.
I'm in for info on turbo porting too!!!
I of course would take care of any rough or bad casting areas, But I would like to know if there are any "KEY" areas to smooth or blend out.
lets here from some turbo gurus!!!
Changing the inside of the turbo exhaust and compressor housing form a 60 grit sand paper texture to a 2500 grit is not going to make it work any better. It just dosant make 1/9 of an horsepower.
