67mm Turbo
67mm Turbo
I have a 67mm Turbo with a .96a/r that is part of my rear mount set-up. Im building the motor now. It will be a 355 9.0 compression with good heads and intake. I have not picked out a camshaft yet because i have not figured out if im going to use this turbo. What kinda boost will this turbo produce and be reliable. i also wounder what size pipe some rear mounts are running when they upgrade the pipes. I have 2 pipe that came with the sts kit, i wanted to upgrade the pipes while i upgraded everything else. Can i run a 2.5 pipe to a 3in intercooler and 3 out to the intake? or will this cause to much of a drop in boost? Will this cause any lag? thanks
Well with the right cam and a safe amount of boost as much power as the heads and turbo will allow me to. its not a street car and it will only have a alternator. I dont know what size pipe i should go with to the new front mount intercooler im going to be adding.
on the same kit in the link in my signature , an intercooled T67:.81 a/r
my buddies forged 'LS1 on 100oct. fuel: 630+ rwhp / 660 tq
https://ls1tech.com/forums/forced-in...ear-mount.html
The Size of the piping itself isnt that major but going off of other turbo cars i have had make sure all your piping is the same size even a 1/4" defference will hurt the flow alot. Again I know nothing about lt-ls turbo cars but know a good amount about turbo cars.
