few procharger questions
so im going a different route with my build and going to procharge my 383. my compression ratio will be around 9.75 to 1. so how much boost would it be able to handle? also who sells a good fmic without breaking the bank and is there anywhere i could buy a kit minus the headunit?
LS1Tech Sponsor
http://shop.brutespeed.com/ATI-3GJBB...I-3GJBB-02.htm
8 Rib Main Bracket and Tensioner
http://shop.brutespeed.com/ATI-DC017...I-3GJDR-08.htm
8 Rib Crank Pulley
http://shop.brutespeed.com/ATI-Perfo...-AT-918853.htm
Balancer for 8 rib Crank Pulley
http://shop.brutespeed.com/ATI-Perfo...-AT-918993.htm
Crank Pinning Kit
http://shop.brutespeed.com/ATI-DPxxx...-ATI-DPxxx.htm
Blower Pulley is various sizes, has belt option
http://shop.brutespeed.com/ATI-3GJAI...I-3GJAI-01.htm
Air inlet assembly
http://shop.brutespeed.com/KN-RE-092...KN-RE-0920.htm
Air Filter
http://shop.brutespeed.com/ATI-ME001...ME001G-006.htm
Head unit oil
http://shop.brutespeed.com/ATI-AV008...AV008A-001.htm
Bypass Valve
A lot of people just buy the above items and come up with the below items on their own, which is why I separated them.
ProCharger Cooling Items
http://shop.brutespeed.com/ATI-98-02...-MF006I-24.htm
Upper/Lower Fan Shroud
http://shop.brutespeed.com/ATI-MP006...I-MP006I-3.htm
Sheetmetal Hold-down
http://shop.brutespeed.com/ATI-MF006...I-MF006I-0.htm
Fan Assembly
http://www.google.com/url?sa=t&sourc...WcGB6Q&cad=rja
Installation Instructions from an old customer named Ed.
Hopefully this helps.
ProCharger offers a universal 1300HP air to air intercooler 3.5" inlet/Outlet $1325.00 shipped
Universal 3.5" tubing kit $180.00
With a good tune and stock style heads you'll be good for approx 16 psi of boost. If you add heads with a thicker deck such as AFR 225's, you can run 18 to 20 psi of boost with a good tune. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
Yes, we did indeed at the old EPP shop, however, this ProCharger universal 1300HP air to air intercooler is a far better intercooler. Bob
__________________
LS1Tech Sponsor
16 psi with 9.75/1 is just fine. You can run high 8's-low 9's with an 31x2x4 intercooler from CX Racing, which is what I was using on my '99 Z28. Bob
__________________
