80mm turbo
Old 11-28-2010, 06:23 PM
yessir's Avatar
Default 80mm turbo
what is the smallest( physical size) t-4 80mm turbo avail? im looking to upgrade from my mpt76 but i have space limitations
Old 11-28-2010, 07:56 PM
Nitroused383's Avatar
Good question, I'd like to know if there is anything that is not a huge 40+lb anchor. It seems once you go past the TC76-78 / PTE76GTS size turbos they just get huge and difficult to package. I still don't see why you can have a TC76 turbo that weighs 20lbs yet can make 6-700 rwhp, and the next step up seems to be a S380 / 480 or a GT4580 which are both huge. There is nothing in between that I am aware of. It seems the best power / size unit might be the PT76GTS but it's not exactly small.
Old 11-28-2010, 09:11 PM
rosey's Avatar
I'd call precision, I'm pretty sure you can at least get a 80mm wheel in a 76gts housing.
Old 11-28-2010, 09:16 PM
99Z28LS1's Avatar
Why not a TC78?
Old 11-28-2010, 11:21 PM
They do not cast their 80mm wheel any more.
Old 11-29-2010, 12:30 AM
Zombie's Avatar
Even if you do cram a larger compressor wheel into smaller housing, you run into the issues of the exhaust side being too small to support the flow of the larger comp wheel.
Old 11-29-2010, 12:51 AM
CL2000's Avatar
forced inductions is who you want to talk to they make alot of there own wheels and have something to do with r&d for alot of turbo companys
Old 11-29-2010, 12:55 AM
gnx7's Avatar
I have a Comp Turbo CT80 T4 (1.15 A/R turbine) rated at 1150hp that is relatively small and weighs 21lbs (alum center section). They are worth a look as well. Triple ball bearing turbos.
Old 11-29-2010, 11:38 AM
lt1773's Avatar
what is your engine size ??
Old 11-29-2010, 12:11 PM
freakyfastlsx's Avatar
go with a tc76 cant beat it
Old 11-29-2010, 06:52 PM
rotary1307cc's Avatar
I never realized you went to a Comp
I have been considering going from the TC78 to a Comp for the larger turbine yet still retain a small/light turbo
but it is hard to find info and specs for them anywhere it seems
do you know by chance the turbine ind/exd on that turbo? or where to find info?
what kind of price too? ~2k?
Thanks!!
Old 11-29-2010, 08:27 PM
Dragframe's Avatar
pt88 is not very big....
Old 11-29-2010, 10:09 PM
Grr
Grr's Avatar
Agree on the Comp turbos
Have used 2 of them on supras and they are unbeleiveable. A triple ball bearing 67mm q-trim with a spool valve on a 2jz (instant boost, like 20psi at 2500rpm)
Then a 74mm MX trim triple ball bearing on a 7m, made 30psi at 5600 and was making well into the 700whp area.
As far as sizing, they use single size turbines, so a 79mm is 79mm everywhere. They also have recently came out with an oil-less triple ball bearing center section that would be perfect for a rear mount, no drain to worry about, ever!
Old 11-30-2010, 01:58 AM
gnx7's Avatar
I'm putting it on a 364ci LS2.
There aren't a lot of people running the Comp Turbo or at least not a ton of info/feedback on them. It is a bit pricey.... If you put a stainless steel Vband turbine housing on them you can shed another 3-4lbs.... Tial and a couple other places make them now.
PT88 has run high 8's on a 370ci setup weighing 3800lbs.... They work too!
Old 11-30-2010, 03:26 AM
venom ws7's Avatar
What about ST80?
Old 12-01-2010, 08:23 PM
yessir's Avatar
not so much concerned with the weight, just size. tc80.....hope your listening turbo gods lol
Old 12-01-2010, 08:48 PM
yessir's Avatar
the comp ct5 looks awsome, but the price
Old 12-01-2010, 11:41 PM
1fastlsx's Avatar
what size turbo would be good for 434lsx afr 225 fast 102 intake or carb set up?
Old 12-02-2010, 12:10 PM
LS1TECH Sponsor
DrTurbo's Avatar
What kind of power?? With a 434...you can spool anything you want.
Old 12-03-2010, 01:37 AM
black98ws6ta's Avatar
PTE Billet 76 or PTE 88. 88 is mid frame and larger. 76 isnt much bigger and will make quite a bit more power then the tc78.
Quick Reply: 80mm turbo
