Stock crank, forged engine--bearings, oil pump, and ring gap for boost?
Old 12-14-2010, 03:49 PM
Snyper's Avatar
Default Stock crank, forged engine--bearings, oil pump, and ring gap for boost?
Im in the process of collecting parts and had a few questions..
1. What main and rod bearings do you guys with stock cranks use for these set ups?
2. What ring gap is ideal for a daily driver car that will see 20psi at the track? Im using the wiseco stainless/napier rings and I dont want a puffer...but it will see a bunch of boost at some point in its life.
3. What oil pump do you use?
Old 12-14-2010, 04:15 PM
NAVY's Avatar
about main bearing CLE-MS2199HK and rods CLE-CB663HNK
Melling Performance Oil Pumps 296
Old 12-14-2010, 04:16 PM
Snyper's Avatar
I was told I can't run Hs on a stock crank.
Old 12-15-2010, 10:15 AM
Gonoma's Avatar
Apparently you can use H bearings
https://ls1tech.com/forums/generatio...ock-crank.html
Old 12-15-2010, 01:30 PM
NoGo's Avatar
Clevite OEM replacement bearings here - nothing fancy.
LS6 Oil Pump. I'm not a fan of aftermarket pumps. In my opinion you don't need the extra pressure if you go with stock clearance bearings and I have more faith in GM QA.
Follow the ring manufacturers recommendations for gap. I got a little too smart and went with a slightly smaller gap than the OEM recommended because I didn't want a puffer (24 I think). Both my #7 and #8 cylinders have a groove on the cylinder wall that I think is from ring contact.
Anyhoo - despite the #7 and #8 groove the motor has held together for almost 30k at 700 HP.
Old 12-15-2010, 06:25 PM
Snyper's Avatar
hmm Well reason for higher pressure is from the turbo. Before the turbo I had great oil pressure. After I added the turbo the pressure dropped. Also, ill be adding an oil cooler which I hear will drop pressure even further.
Old 12-15-2010, 07:49 PM
blue00ZZleeper's Avatar
I went with .026 on my top and .024 on 2nd. Should handle the pressure pretty well. Its a hellfire ductile iron top and a napier 2nd. I went with a Melling's pump.
Old 12-16-2010, 12:20 AM
Snyper's Avatar
I see a Clevite MS2199HK and a Clevite MS2199H....whats the K stand for?
Quick Reply: Stock crank, forged engine--bearings, oil pump, and ring gap for boost?
