Twin MP61s vs PT76gts on 370
Hey guys
Im real close to buying turbo parts for my 370. Its going into my 67 Camaro Stick car. just street driven, no track time. stock 317 heads and lq4 cam for now. forged pistons and rods, arp main and head studs...
Wanted to get your thoughts on twin Master Power T61s vs something like a PT 76gts
I dont want laggy, but i dont want to be done by 5800 rpm either. But, I dont want boost when im trying to cruise for mpgs
Goals are 650-700 at the wheels with a bit of room to grow.
what do you think?
thanks
what do you think?
thanks
well, im leaning toward the master power stuff because its cheaper. i realize that they probably arent going to give me every last drop of hp compared to precision or others.
so this t61 is about as close to that 6265 as i could find
810041-068 T-61 / P-TRIM 500-550 .70 101.7 64.0 61.0 91.0 45 6 .68 T4 V-BAND UNDIVIDED 64.5 74.0 76 10
ive been told that twin mp t61s might max out right at 800 rwhp. a PT76gts is about the same, right?
keep the opinions coming
I would want more compression than that unless you already have the pistons. If you already have the pistons use some ls6 heads. Your just making it harder on yourself as the stock lq4 cam doesnt have any advantage especially since ls6 cams are around $100. Depending on what year your cam is it would be
191/190 .457/.466 114 or
196/207 .467/.479 116
Both are turds on a stock motor let alone a 370. If you want a sleeper the ls6 cam is still silent but just a little better and super cheap.
204/218 .555/.551 117.5 02-04 ls6 cam specs
i already have the pistons, but the 317s do need cleaned up, so if needed, i can mill them a bit. what CR do you recommend?
ok, ill just stick the ls6 cam in now. is that 100 bucks new?? or used?
thanks
thanks
my "argument?" man, there are some touchy guys here ... i didnt know we were in a debate here?
heres the guys post. primarily a street car, made good power, street car. like mine. ill take a power curve like his any day. i just wanted to ask other folks for their thoughts before i shell out a bunch of cash.
https://ls1tech.com/forums/forced-in...04ci-76mm.html
looks like folks like the t61s anyway.
thanks guys
thanks guys
do u carry any internal wastegated t3/t4 turbos? i didnt see any listed on the site.
op sorry for
just trying to get idea to see whats available. kinda in the same boat.
even using modded a pair of toyota ct26s or gn turbos has crossed my mind.
OWN3D BY MY PROF!
Those turbos are only $275 less than a PT6262/65. http://shop.virginiaspeed.com/produc...&categoryId=35
Do it right and do it once. You'll have plenty of room to grow with the PT62s
9:1 Compression on Cali gas isnt an issue. He isnt building a racecar here running on racegas all the time.
the 4G63 was 7.8:1 from the factory. Id say Mitsubishi did well building that engine
