turbo iroc 88mm l92 402 lq9 build
Old 03-14-2011, 03:06 PM
  #41
TracyRR's Avatar
Nice build! Yes, the valve covers look nice but the ebay pair i bought leaked its *** off..... the rubber o-ring was seated right on the edge of the valve cover rail (head) so i went back to stock. Best of luck
Old 03-14-2011, 03:15 PM
  #42
turbo iroc's Avatar
Ok thanks ill keep that in mind, I still have the stock covers if need be.
Old 03-14-2011, 03:25 PM
  #43
PRAY HRD's Avatar
Originally Posted by turbo iroc
heres a link to those valvecovers, anyone ever have trouble with these?
Those would be awesome without the coil pack boss'! They have some without for $225 MORE!! WTF?!
Edit....that was to a different ebay store i saw at the bottom. My bad! Wish they made them without the boss' so you could relocate the coil packs and have an inexpensive alternative for a sharp looking valve cover!
Old 03-14-2011, 04:00 PM
  #44
Closed ex-Sponsor Account
408trans_am's Avatar
Yea I have never heard anything good about those ebay fabricated valve covers. They all leak. Maybe a lot of rtv.
Old 03-14-2011, 04:40 PM
  #45
MaxxMitchell's Avatar
I run a set on a race car, you will need to weld tabs along the rails, similar to what the stock ones have to keep them centered on the heads.
Old 03-14-2011, 07:14 PM
  #46
turbo iroc's Avatar
Thanks! That helps alot, they don't have anything to center them that's correct. Shouldn't be hard to make them work tho.
Old 04-29-2011, 09:16 PM
  #47
turbo iroc's Avatar
Sorry no updates guys still waiting on my brother to finish up his project. Probably wont make it to oc Maryland this year either.... hopefully have this thing running before summer hits.
Old 06-02-2011, 07:11 PM
  #48
turbo iroc's Avatar
ok finally got started on this thing and got alot done today!
removed engine and trans and also degreased, pressure washed, and painted the engine bay
engines going in tomorrow
Attached Thumbnails turbo iroc 88mm l92 402 lq9 build-226.jpg   turbo iroc 88mm l92 402 lq9 build-228.jpg   turbo iroc 88mm l92 402 lq9 build-232.jpg   turbo iroc 88mm l92 402 lq9 build-234.jpg   turbo iroc 88mm l92 402 lq9 build-236.jpg
Old 06-03-2011, 08:22 PM
  #49
turbo iroc's Avatar
motor and trans in!
Attached Thumbnails turbo iroc 88mm l92 402 lq9 build-006.jpg   turbo iroc 88mm l92 402 lq9 build-013.jpg
Old 06-04-2011, 12:29 PM
  #50
73 nova guy's Avatar
nice looking build! frank at psi is very good to work with he tuned my car.
were you located?
Old 06-04-2011, 03:58 PM
  #51
turbo iroc's Avatar
Thanks! Yea Frank's a good Guy ill probably bring it back to him to have it dynoed. I'm in Bethlehem on the edge of hellertown.
Old 06-04-2011, 09:24 PM
  #52
turbo iroc's Avatar
ok got a a little more done today; got most of the engine wired up then alot of head scratching as far as turbo placement. leaning towards the center mount option. also a shot of all the hotside parts.
Attached Thumbnails turbo iroc 88mm l92 402 lq9 build-002.jpg   turbo iroc 88mm l92 402 lq9 build-004.jpg   turbo iroc 88mm l92 402 lq9 build-006.jpg   turbo iroc 88mm l92 402 lq9 build-012.jpg   turbo iroc 88mm l92 402 lq9 build-009.jpg
Old 06-05-2011, 02:00 AM
  #53
smokinponcho73's Avatar
That is sweet. I hope to hear how it does. I am doing a similar build except I will be running an l76 intake on a 408. How did you decide on that cam? I was thinking of one really similar.
Old 06-05-2011, 02:17 AM
  #54
turbo iroc's Avatar
Thanks! I saw a build in car craft magazine with a similar Cam and then I did some research and found that the l92/ls3 heads favor a large duration on the exhaust. So I called comp cams and this is what they recommended. I think it'll do well being this a mostly street car with a manual trans.
Old 06-05-2011, 01:33 PM
  #55
I have been emailing comp back and forth and they just stopped emailing me last week. They might be busy or something. I will probably just do a similar cam since we have almost identical builds.
Old 06-05-2011, 01:38 PM
  #56
turbo iroc's Avatar
Yea it should work well I think. The Cam in the article was 231 239 with a little over 600 lift. I chose to go a little smaller because of the valvesprings I'm running. Comp 918.
Old 06-05-2011, 02:27 PM
  #57
Yeah my last build was a 408 with the ms4 with .649" on the intake and you have to run even harder springs then you would with just .600" Did you port your heads at all? I am going to on the exhaust side just to help it out a tiny bit.
Old 06-05-2011, 04:24 PM
  #58
turbo iroc's Avatar
No the heads are bone stock minus the springs. They should perform well tho. I'd like to step up to mast heads in the future.
Old 06-05-2011, 07:57 PM
  #59
turbo iroc's Avatar
we've decided on the center mount option. this turbo is huge (42lbs!) and while putting it in the corner could be done it would require us to chop the car up a bit to make it work. so we decided the center mount would be the best way to go. one draw back is ill have to buy a new radiator, a shorter rad that will tuck up and under the rad support. summit's got great deals on radiators so we decided on one that was 15in tall and 32 in wide and should be plenty capable of keeping the motor temps in check. we also have to figure something out with the fans. i had twin stock iroc fans in between the rad and the intercooler in a pusher configuration before, but its clear they will be way too large to fit in between the rad and the intercooler with the rad pushed back. so ill either source some thin units that'll fit or possibly put one fan on each side of the turbo in a puller configuration.
i also cleaned up the wiring under the dash and finished wiring up the gauges and also finished up the fuel system under the hood (moved the fuel pressure regulator and bolted the carb on) while my brother fabbed up a bracket to hold the turbo. Pics!
Attached Thumbnails turbo iroc 88mm l92 402 lq9 build-002.jpg   turbo iroc 88mm l92 402 lq9 build-003.jpg   turbo iroc 88mm l92 402 lq9 build-006.jpg   turbo iroc 88mm l92 402 lq9 build-008.jpg   turbo iroc 88mm l92 402 lq9 build-010.jpg
turbo iroc 88mm l92 402 lq9 build-012.jpg   turbo iroc 88mm l92 402 lq9 build-014.jpg
Old 06-06-2011, 08:43 PM
  #60
turbo iroc's Avatar
made a little more progress today got the headers tacked up and almost complete.
Attached Thumbnails turbo iroc 88mm l92 402 lq9 build-002.jpg   turbo iroc 88mm l92 402 lq9 build-004.jpg   turbo iroc 88mm l92 402 lq9 build-006.jpg   turbo iroc 88mm l92 402 lq9 build-008.jpg   turbo iroc 88mm l92 402 lq9 build-010.jpg
Quick Reply: turbo iroc 88mm l92 402 lq9 build
