turbo iroc 88mm l92 402 lq9 build
Old 06-23-2011, 04:22 AM
  #81
turbo iroc's Avatar
No comments?! oh well anyway this thing is pretty much done. Got the radiator hose and new bov installed. Also did all the boost/vacuum lines. Just a couple more bugs to work out and oh also needs a windshield and inspection. Here's a vid, thus thing is quiet with the exhaust hooked up!
http://www.youtube.com/watch?v=eSl_Kswzlz4
Old 06-23-2011, 09:22 PM
  #82
KagA152's Avatar
lookin good. maybe i missed it, but what mounts are you running? i cant believe you got that 88 in there, my 70 barely fits with spohn mounts. have any close up pics of how you mounted the radiator? I just have to get my radiator mounted, fab dp, and do the fuel system and i should be ready to go
Old 06-23-2011, 10:13 PM
  #83
turbo iroc's Avatar
Thanks man! The mounts I'm using are stock third Gen mounts with the adjustable brackets that mount to the block. They give you three positions, neutral, 1in forward and 1 in back. I ended up using the 1 in back position as it keeps your transmission in the original location. Thus I didn't have to mess with the driveshaft or shifter location. The radiator is a Griffin brand from summit. It measures 15.5 in high x 31in wide and 3 in thick. It tucks up nicely under the Rad support giving and extra 2-3 of room for the Turbo. Ill see if I can find a pic of the Rad mounts. Basically they're just 2 aluminum "L" brackets welded to the radiator with a bolt going thru the Rad support to the bracket. The cool thing is we didn't have to cut the car up at all to fit this setup, it should fit in any third Gen.
Old 06-23-2011, 11:14 PM
  #84
turbo iroc's Avatar
I'm on my phone so I can't post pics right now but there's a good pic of the radiator on page 4 of this thread. Its a pic of the Rad in the engine bay, you can see the Rad mounts well.
Old 06-28-2011, 07:31 PM
  #85
smokinponcho73's Avatar
Can't wait for some action videos.
Old 06-29-2011, 08:43 AM
  #86
turbo iroc's Avatar
Soon...
Old 06-29-2011, 09:47 AM
  #87
Build-it-Break-it's Avatar
LS1Tech 10 Year
Nice build, Sounds mean
Old 06-29-2011, 11:07 AM
  #88
turbo iroc's Avatar
Thanks! Feels good on 5 Psi
Old 07-01-2011, 10:46 PM
  #89
turbo iroc's Avatar
Small burnout on 5 Psi, should've stayed in it longer...
http://www.youtube.com/watch?v=-oSMH...eature=feedwll
Old 07-01-2011, 11:01 PM
  #90
Nice.
Old 07-02-2011, 11:27 PM
  #91
j88l98irocz's Avatar
Weak George!
You should have hit 2nd and 3rd looks great bud it'll really come alive when you turn up the boost. I still want a ride don't forget...
Old 07-03-2011, 11:01 AM
  #92
turbo iroc's Avatar
That was actually second gear lol. You'll get your ride bud don't worry! I wanna put a Meth kit on then ill crank up the boost and put it on the dyno
Old 07-03-2011, 09:31 PM
  #93
Are you not running an intercooler?
Old 07-03-2011, 09:51 PM
  #94
turbo iroc's Avatar
Yes I am, its a treadstone brand I forget the dimensions tho...
Old 07-04-2011, 11:21 AM
  #95
turbo iroc's Avatar
The core is 26 x 6 x 3.5. Treadstone claims its good for 1000 HP.
Old 07-04-2011, 11:26 AM
  #96
turbo iroc's Avatar
This is the one I have.
http://www.treadstoneperformance.com...es+Intercooler
Old 07-13-2011, 09:21 PM
  #97
chevy1120's Avatar
hey im working on a 88 iroc and was looking for a lil help iv got a lq9 408 stroker i got eagle crank and rods i know the bolts r good till 1250hp so idk like to stay around 1000 or so low compression diamond pistons idk if u guys can help with where and what kinda head and cams to get and any other info u can give would be great im also using a 150 shot of nos and its going to be carb
Old 07-13-2011, 10:29 PM
  #98
turbo iroc's Avatar
The weak link in these motors is keeping the heads down. Anything over 1000hp will most certainly cause issues with pushing water, blowing head gaskets etc. People say that going with an aftermarket thick deck head, upgrading to 1/2 in head studs and o ringing the block are a solution. To be honest I wouldnt try to push it to 1000hp unless I had an lsx 6 bolt block and 6 bolt heads. Its been done before many times but its just something I wouldn't be comfortable with. As for heads, mast motorsports makes a killer thickness deck l92 head, a little pricey tho at about 3k. Cam I'd go with something I. The 240s duration and 650+ lift. Then again it depends on if its for street or strip stick or auto. I'm running a 230 238 575 585 on 114. It has great street manners and 14in vacuum at idle.
Old 07-14-2011, 09:09 AM
  #99
chevy1120's Avatar
i was thinking 237/242 .603/.609 i was told over 600 u gotta start to worry bout valve float its gonna be mostly street but ill take her to the track sometimes im using a 350 turbo trans for now cuz i already have a built one so saves some money any other ideas for where to get heads 3 is a lil high the cheaper i can go with out getting cheap stuff the better what ya think would be best cc for the chamber?
Old 07-14-2011, 10:03 AM
  #100
turbo iroc's Avatar
That Cam seems fine, little big for my liking but considering you'll be auto it should work well. As far as tshe heads go afr, tsp, etp are all great aftermarket heads, just not sure if they offer an l92 style square port head. The l92s are a great stock head, they flow 320 cfm out of the box, 2.16 valves, 265 CC runners, just the thin deck holds back their potential. A few stock style head options are the l92, ls3, lsa, and ls9. They're all square port and flow ridiculous numbers but again the thin deck. The ls9 heads are little better in that they use a different alloy, different casting method and use larger diameter head bolts/studs. The lsa heads are from the supercharged caddilacs, they are similar to the ls9 heads round on the zr1 vettes but I'm not sure of what the differences are. As far as CC heads go that will depend on how much compression you want to run. Mine came out to 9.3 with a 70cc head. The other option is to go with cathedral style heads, there's tons of those in aftermarket brands, but again they're not cheap. Maybe get a used set?
Quick Reply: turbo iroc 88mm l92 402 lq9 build
