Which spark plugs for Turbo
Old 02-05-2011, 02:31 AM
lt1773's Avatar
Default Which spark plugs for Turbo
i have this Turbo motor and i want to buy the proper spark plugs for the motor but i do not know which one to take ,need your input :
-LS3 416ci
- Garrett Gt-91
-Eldrbrock 245 heads WCCH
-Boost will be 18-23 lbs
-120-160 lbs injectors
BR7EF ,NGK TR6 ,TR7,......
what is the best choice ?
Old 02-05-2011, 08:43 AM
02blackbeauty19's Avatar
I'd go with at least a 7 heat range plug (BR7EF). Possibly even an 8.
TR6 is going to be way too hot by most peoples standards.
Old 02-05-2011, 09:21 AM
7 Second Club
NicD's Avatar
NGK B8EFS (stock #1049) / Autolite AR474 for starters
NGK B9EFS (stock #1085) / Autolite AR473 for another step colder
Old 02-05-2011, 10:34 AM
7 Second Club
Phil99vette's Avatar
do those heads require a .750 or .705 reach and gasketed or taper seat?
Old 02-05-2011, 10:41 AM
lt1773's Avatar
taper seat
Old 02-05-2011, 10:55 AM
7 Second Club
Originally Posted by lt1773
taper seat
Which reach do those heads require?
Old 02-05-2011, 02:34 PM
7 Second Club
NicD's Avatar
Stock style/length I believe.
Old 02-05-2011, 02:55 PM
7 Second Club
You cant assume, call and find out. Most aftermarket heads require 3/4" reach.
Old 02-05-2011, 03:22 PM
7 Second Club
NicD's Avatar
C'mon this isn't difficult, look on their website they specify factory style/length like a TR55 just like AFRs do.
Old 02-05-2011, 04:37 PM
7 Second Club
Your right this isn't that difficult so buy whatever plugs you want. You asked for the correct ones. AFR requires a 3/4" reach plug and the TR55s are .691. Factory heads dont use a .750 reach plug while most if not all of the aftermarket ones require a .750 reach.
Old 02-05-2011, 04:54 PM
LSXFORMULA99's Avatar
TR7s...
Old 02-05-2011, 04:57 PM
7 Second Club
NicD's Avatar
I guess I don't understand the pissing match. He can use the regular OE style taper seat plugs just like you can with an AFR head or a stock head depending on how far he wants the plug to project in the chamber and as far as I'm concerned pulling the tip out of the chamber is preferred for the build he is doing which is why I suggested the plugs I did. He asked for suggestions on a place to start and you are making a big deal out of something pretty inconsequential but whatever.
Old 02-05-2011, 04:58 PM
7 Second Club
Since you asked for the correct plug.
After 2 minutes of searching, the edlebrock head uses a .708 x 14mm tapered plug. Get the Autolite AR94 racing plug.
Old 02-05-2011, 05:08 PM
7 Second Club
NicD's Avatar
An AR94 is just a projected tip version of the plugs that I listed in the first place with damn near identical lengths. Personally I don't run projected tip plugs on any bigger power build but that's just my preference.
Old 02-05-2011, 05:10 PM
7 Second Club
NicD's Avatar
Originally Posted by LSXFORMULA99
TR7s...
There is no such plug.
Old 02-05-2011, 06:14 PM
mike13's Avatar
Just installed a set 3 day ago.
Old 02-05-2011, 06:20 PM
7 Second Club
NicD's Avatar
Oh really, what was listed on the box and what's the NGK stock number? NGK doesn't refer to any 7 heat range or colder copper plug as a TR anything.
Old 02-05-2011, 06:31 PM
mike13's Avatar
It said TR7 on the box, I ordered them from Nasty with MSD wires.
Old 02-05-2011, 07:08 PM
7 Second Club
NicD's Avatar
Show me a picture, I would bet it says BP7EFS on the box since a TR7 doesn't exist.
Old 02-05-2011, 07:13 PM
i used tr7's also. u suck!!!
Quick Reply: Which spark plugs for Turbo
