Trap speed with 9-10 psi
What are most people trapping in the quarter mile on stock cubes and 9 to 10 psi? Please post time, mph, weight, and m6 or auto
Ok, well you guys can post any combo, I'm particulary interested in ls1 f-bodies, supercharged. I know airflow is different than psi, but I'm asking 9 psi
I would go into the dyno forum and do a search, the problem with what your asking is boost is a measure of restriction. So 9 psi on a completely stock motor might only be 6 psi on a modified better flowing motor. You could have numbers from 400rwhp-700rwhp
I would do a search in the dyno forum and see if you can find combinations that match closely and then put those numbers into a 1/4mile calculator.
