GMHTP - Standing Mile build (88mm, 370... 200+mph)
Old 06-30-2011, 06:08 PM
  #41
ls2 bait's Avatar
looks sick Justin. can't wait to see it finished.
Old 07-01-2011, 11:49 AM
  #42
sq_creations's Avatar
It has been fun watching the build. I really like the rendering too. My one question is, are you guys worried about the charge pipe getting heat soaked after it leaves the intercooler? It looks pretty close to the exhaust on both sides.
Old 07-01-2011, 12:31 PM
  #43
Canbarelygo's Avatar
the downpipe reminds me of this car
http://www.1320video.com/img/TX2K11W...1741.sized.jpg
the trans am is gonna look sick though
Old 07-01-2011, 01:18 PM
  #44
93M6Formula's Avatar
That looks like more of an UP pipe to me haha
Sick car though can't wait to see the results!
Old 07-01-2011, 04:01 PM
  #45
93camaro_zzz's Avatar
roflcopter
Old 07-01-2011, 07:11 PM
  #46
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
It would be interesting cruising down track seeing the heat or a possible fireball coming at you.
Old 07-01-2011, 09:00 PM
  #47
NemeSS's Avatar
Fbody accesory drive?
Old 07-02-2011, 12:29 AM
  #48
72montecarlo's Avatar
Without a doubt the sickest turbo kit on an f-body I have seen
Old 07-06-2011, 09:09 AM
  #49
LS1Tech Sponsor
Justin@GMHTP's Avatar
Originally Posted by 93camaro_zzz
Hello fellow GMHTP readers and staff,
First off let me say that as a long time reader, you guys at GMHTP never fail to impress! Awesome issue this month! I just was studying the article entitled "Turbocharging 103: Cold side" and I had some questions about it.
I own a 2000 WS-6 with a 370 LQ9 with the APS twin turbo setup on it, and I was looking very much in to the Edelbrock Pro-Flo intake you guys used. My questions are:
1. Did you guys have to modify the WS6 hood at all to allow this to fit?
2. Did you have any specs or diagrams for the cut you made to the cowl, so if readers wanted to do this, they could it as well?
3. Is it required/recommended to have solid motor mounts with your setup since its such a close fit in the cut in the cowl?
4. Does the new edelbrock intake accept most aftermarket fuel rails? I have a set of the trick flow brand high flow fuel rails.
Thanks in advance for information, and as always I eagerly await your next issue!
1. Yes, we are going to have to cut a small section of the hood to clear the throttle body/intake mounting location. I don't have pictures yet, but we will have them in an upcoming issue. This is only a "trim" to the bottom of the hood, it won't be noticeable with the hood shut.
2. We don't have any diagrams at this time but it is fairly easy to see where you need to cut as soon as you drop the Pro-Flo XT in place. If you get one and need additional help, PM me and I will get you some rough measurements.
3. No, you don't need solid mounts with the Edelbrock. Depending on how narrow or wide you make your cowl cut, you can give it some room to rock under power. I would recommend at least poly mounts with the power/torque that you should be making.
4. We haven't installed any fuel rails yet, so I can't comment on fitment. Sorry!
The cold side aluminum pipe does come quite close to the driver's side crossover, so we will be adding some thermal protection (JetHot) to that area. The pictures make it look closer than it is, but it's definitely tight... good eye.
Just running an electric water pump and an alternator. No other accessories planned at this time.
Thanks! We couldn't have done it without a ton of help from everyone involved in the process.
Motor build starts soon... updates as soon as we get them!
Old 07-06-2011, 11:23 AM
  #50
MaxxMitchell's Avatar
Keep an eye on the down pipe distorting after long hot pulls. The aluminum will change in all kinds of cool ways, or atleast the 5" DP did on a 106mm/SB2 400 that raced in a local 275 class after half a season.
Cool build, and very mag worthy.
Old 07-06-2011, 11:41 AM
  #51
KILLER-LS1's Avatar
where do you guys plan to race at? and when?
Old 07-06-2011, 12:00 PM
  #52
LS1Tech Sponsor
We're certainly interested in seeing what the aluminum DP will do over time (and over the course of a mile)! How much movement did you see?
We would like to run in Texas and probably Maxton (or, wherever that ends up being). Bonneville would be great too, but that is more of a dream than something we have planned at this time. As for the time, we've got a long way to go, but hopefully sooner than later.
Old 07-07-2011, 01:18 PM
  #53
Thanks for answering my question Justin. Good luck with the rest of your build!
Old 07-09-2011, 10:44 AM
  #54
V-seriesTech's Avatar
Another awesome build. Sick. loving the standing mile plans. Best wishes, rendering looks dope
Old 07-09-2011, 01:12 PM
  #55
Jenson's Avatar
IIRC, in the article it said the DP is aluminium? How is that gonna work? Or did I read it wrong? The mag is at work, I like to dream on lunch break
Old 10-05-2011, 01:25 PM
  #56
Turnin20s's Avatar
Any updates??
Old 10-05-2011, 05:02 PM
  #57
narx66gmc's Avatar
what a cool location for the turbo!! thi sis abeautiful build and the rendering looks awesome!!
Old 10-05-2011, 08:12 PM
  #58
fast00ls1's Avatar
Will u guys have this car and the sti killer at the lsx shootout this weekend!
Old 10-05-2011, 08:39 PM
  #59
stangtrader's Avatar
Sick build can't wait to see more
Old 10-06-2011, 12:10 AM
  #60
Sandmann120's Avatar
Very cool build. Can't wait to see more.
Quick Reply: GMHTP - Standing Mile build (88mm, 370... 200+mph)
